[GRASS-user] Re: GRASS freezes with OpenSuse 11.0
I have the same problem with GRASS 6.3.0 downloaded from grass.itc.it under OpenSuse 11.0 32-bit. I have latest GDAL, Postgresl etc.
Francesco Teodori has created 32-bit rpm's for Suse 11 and GRASS 6.3.0, so he must know what we are doing wrong. I have not tried the rpm's:
http://teodori.org/repository/grass/opensuse11.0/current/32bit/grass-6.3.0-1opensuse11.0.i586/download.html
I have the same freeze problem with GRASS 6.2.3 and GRASS 6.3.0-svn from 2 weeks ago, both downloaded from grass.itc.it, so the freeze problem is not specific to either 6.3 release or 64-bit. Something in OpenSuse 11 must be the trouble, but what?
Bill Baker
Message: 2
Date: Thu, 21 Aug 2008 11:00:30 -0300
From: "Adalberto da Silva" <adalberto_s@uol.com.br>
Subject: [GRASS-user] Grass freezes with OpenSuse 11
To: "'grass'" <grass-user@lists.osgeo.org>
Message-ID: <20080821135923.DFC02F59@socom10.uol.com.br>
Content-Type: text/plain; charset="us-ascii"
Hello!
I am trying to launch Grass under OpenSuse 11 - 64, rpm packages from
teodori.org, but it freezes just after I confirm the project I want to work
with.
I can enter the initial Grass window, it shows me the projects I have in my
disk but it does not open it. I only get two frozen windows: "Output -
GIS.m" with several frozen buttons ("save", "Clear", "Run", "Run in
Background", "Run(GUI)" and "Run (in Xterm)") and a second screen always on
top and fixed with the title "GRASS6.3.0 GisManager - **name of the project
I tried to open**" and a "Done" message button.
In order to get rid of these windows, I must kill the 'wish' process.
I tried to uninstall and reinstall it but it does not work yet.
Does you have any clue about this?
Adalberto da Silva
LAGEMAR-UFF
Brazil
Is there an error message shown in the terminal window?
e.g. something about libgdal.so? or missing nsres() variable?
can you start in text mode ('grass63 -text') and run 'g.region -p'?
I expect there is some build error with those binaries, or GDAL libraries
on your system have been updated to a newer version than those binaries
were built with and are now incompatible.
I see on the download site there is a new grass-6.3.0-13.1.i586.rpm
added three days ago. Perhaps that solves it?
Hamish
