I list,
I've build python_grass6.so and python_grass6.py with make from MakeFile in swig/python directory but if import the library:
import python_grass6
I've that error from python interpreter:
File "<stdin>", line 1, in <module>
File "/usr/lib/python2.5/lib-dynload/python_grass6.py", line 7, in <module>
import _python_grass6
ImportError: /usr/lib/python2.5/lib-dynload/_python_grass6.so: undefined symbol: __stack_chk_fail_local
Or, in IDLE:
File "<pyshell#0>", line 1, in <module>
ImportError: libgrass_I.so: cannot open shared object file: No such file or directory
I'm not a python guru. Could anybody help me?
Thanks
Gianluca
On Wed, Aug 27, 2008 at 9:32 PM, g_massa@libero.it <g_massa@libero.it> wrote:
I list,
Not sure about above, but:
Or, in IDLE:
suggests that LD_LIBRARY_PATH isn't properly set.
I have:
cat /etc/ld.so.conf.d/grass.conf
/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/lib
(adjust path to your installation, save as "root" user and
run ldconfig then - I assume that you use Linux).
