[GRASS-user] Re: grass-user Digest, Vol 24, Issue 10
Edmondo,
Dear All,
I've imported a .PNG file with r.in.gdal (i.e. map.png) in order to make a
georeferencing file. The importing procedure returned 3 files: map.red,
map.green, map.blue. I don't know how continue to reach my goal.
Thanks in advance
Edmondo
When I was a raw newbie, georeferencing caused me no end of pain! So I'll give you the long answer. Note: there is a single-tool interface to georeferencing, but I find it's easiest and most reliable to follow the individual tool steps (i.group, i.target, i.points, i.rectify).
1) "Target" map
You must have something to georeference your input map against. So if I was looking at an image of Sydney, it's best if I already have a raster map of Sydney in my target location (the place I want the georeferenced input to end up in). If you have a vector map in the target location, you'll have to do more typing!
2) Import image to *new* location
From your message, I guess you've already done this!
3) Create a group
By creating a group containing your red, green and blue layers, you will ensure that rectification happens to all three. For this, you use the i.group command:
i.group group=<groupname> input=<red map name>,<green map name>,<blue map name>
4) "Target" the group
In this step, you're telling Grass-GIS "These maps will end up being georeferenced against this location". So you might have:
Import_Location > PERMANENT
to be georeferenced to:
Target_Location > PERMANENT
Running in your Import_Location, PERMANENT mapset, you run i.group:
i.group group=<groupname> location=Target_Location mapset=PERMANENT
5) Capture georeferencing points.
In an X monitor, you will display your imported image (one layer only - because red, green and blue are in the same group, they will all be rectified together later). If you have a raster image of the target location in Target_Location, you can display this next to your imported image, and just use mouse clicks to capture ground control points. If you don't have a comparable raster image, you'll have to use latitude-longitude of your ground control points.
What you're doing in this step is telling Grass-GIS "This location in the imported map is equal to these co-ordinates in the real world".
First, open the X monitor:
d.mon start=x0
Next, start i.points
i.points group=<groupname>
If you have a "target" raster:
The window will ask you to choose the map to display on the left (this is your imported map). If you have a reference map available in Target_Location, select the PLOT RASTER button at the bottom and click on the right-hand side of the X monitor. This will allow you to select a map i the target location. Then, if you click on a point on the left-hand side, and click on a corresponding point on the right-hand side, Grass-GIS will capture coordinates for you.
If you don't have a "target" raster:
You will need to have co-ordinates for known points in your imported map. Click on a point in the map, and type the co-ordinates into the terminal window that opens.
It works best if you select points at the corners of your imported map. If you can identify co-ordinates at the four corners, this should be sufficient.
6) Rectify
Now, you just need to run i.rectify:
i.rectify -a group=<groupname> extension=<string> order=<value>
The -a flag tells Grass-GIS to rectify all maps in the group (red, green and blue). The extension is necessary, but can be anything you like (I usually use _rectified as the extension). This will be added to the existing map names in the target set. Order is the polynomial order you use for the calculation - if you only have four points at the corners, then order=1. So I rectify will look something like this:
i.rectify -a group=<groupname> extention=_rectified order=1
7) Check
Open Grass-GIS, enter your target location, and display the rectified version of your map to see if it worked.
Hope this makes it all clear!
Richard Chirgwin
