[GRASS-user] Re: grass-user Digest, Vol 24, Issue 36
This originally pointed to the directory specified in the variable
PROJ_SHARE, that was supposed to be set at compile time. It should not point
to root unless PROJ_SHARE is not set. This is because the EPSG data file is
in different locales on different platforms.
Michael
On 4/17/08 3:30 PM, "grass-user-request@lists.osgeo.org"
<grass-user-request@lists.osgeo.org> wrote:
Date: Fri, 18 Apr 2008 00:30:19 +0200
Subject: Re: [GRASS-user] Command completion in wxpython-GUI: is it
possible(?) + an issue with the EPSG file browser.
To: "Nikos Alexandris" <nikos.alexandris@felis.uni-freiburg.de>
Cc: grass-user <grass-user@lists.osgeo.org>
Message-ID:
<f8fe65c40804171530g30289eedi8761f33091f53dcc@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
2008/4/17, Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
Dear wxpython developers,
is it possible to add command completion in the new GRASS-GUI?
sure, one of TODO's:-)
http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS#Roadmap
Another issue with the "location wizard":
location wizard > next> select EPSG code of coordinate system > Browse:
in the "choose EPSG codes file" window the browser refuses to show all
files in the directory /usr/share/proj as instructed.
Manual typing epsg works fine and I can read the epsg file.
now fixed in trunk,
http://trac.osgeo.org/grass/changeset/31026
Originally file dialog pointed to 'root directory', but anyway I
figured out that loading other files then 'epsg' fails, since slightly
different file structure. I will try to fix it ASAP.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
