grass-user-request@lists.osgeo.org wrote:
Send grass-user mailing list submissions to
grass-user@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
grass-user-request@lists.osgeo.orgYou can reach the person managing the list at
grass-user-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-user digest..."Today's Topics:
1. Re: Importing DEM into 3D Studio MAX (Marco Pasetti)
2. Grass freezes with OpenSuse 11 (Adalberto da Silva)
3. Re: Importing DEM into 3D Studio MAX (Jarekj)
4. Re: common legend for the set of maps (Michael Barton)----------------------------------------------------------------------
Message: 1
Date: Thu, 21 Aug 2008 14:54:14 +0200
Subject: Re: [GRASS-user] Importing DEM into 3D Studio MAX
To: <francesco.pirotti@unipd.it>, "GRASS Users"
<grass-user@lists.osgeo.org>
Message-ID: <9A48A6FB282C44C4BCE45C7231475D5C@HPMarco>
Content-Type: text/plain; format=flowed; charset="iso-8859-1";
reply-type=originalHi Francesco,
Another idea is to export the DEM in grey scale, many 3D packages have an
option to create terrain from greyscale 8-bit images, very handy if you
ask me.
interesting. Do you know how could I import a raster DEM as 3D terrain model into ArchiCAD?
ArchiCAD doesn't recognize VRML and I don't have 3DS (recognized format by AC) to convert VRML to 3DSMax
I also tried importing a shp contour vector layer (derived from the raster DEM), but it seems that AC don't "read" the z values (the layer is imported as simple plain curves)any ideas?
Marco
Message: 2
Date: Thu, 21 Aug 2008 11:00:30 -0300
From: "Adalberto da Silva" <adalberto_s@uol.com.br>
Subject: [GRASS-user] Grass freezes with OpenSuse 11
To: "'grass'" <grass-user@lists.osgeo.org>
Message-ID: <20080821135923.DFC02F59@socom10.uol.com.br>
Content-Type: text/plain; charset="us-ascii"Hello!
I am trying to launch Grass under OpenSuse 11 - 64, rpm packages from
teodori.org, but it freezes just after I confirm the project I want to work
with.I can enter the initial Grass window, it shows me the projects I have in my
disk but it does not open it. I only get two frozen windows: "Output -
GIS.m" with several frozen buttons ("save", "Clear", "Run", "Run in
Background", "Run(GUI)" and "Run (in Xterm)") and a second screen always on
top and fixed with the title "GRASS6.3.0 GisManager - **name of the project
I tried to open**" and a "Done" message button.In order to get rid of these windows, I must kill the 'wish' process.
Can you check: is there a window you can't see behind the ones you can see? I remember getting this problem - the locked windows on top obscured a "child process exited abnormally" window, which stopped me from pressing the OK button ...
There is a dependency missing somewhere, but I can't remember which one; I simply went back to the installation of all the required libraries and started from scratch!
Richard Chirgwin
I tried to uninstall and reinstall it but it does not work yet.
Does you have any clue about this?
Adalberto da Silva
LAGEMAR-UFF
Brazil
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080821/e8568f45/attachment-0001.html------------------------------
Message: 3
Date: Thu, 21 Aug 2008 17:08:30 +0200
To: Wolf Bergenheim <wolf+grass@bergenheim.net>
Cc: GRASS Users <grass-user@lists.osgeo.org>
Message-ID: <48AD84EE.2030009@amu.edu.pl>
Content-Type: text/plain; charset=UTF-8; format=flowedwell imho most simple method would be export dem in gray (any graphical format) and use it as displacement map in 3dMAX or use it as the map in displacement modifier. I used this method years ago to presend 3d relief. It gave me very interesting result.
Second method is to change grid into 3dpoints, export it to vrml import vrml to 3dMAX (I don't know now if 3dMAX handle vrml natively) and convert points to mesh. But result cut be... any
JarekWolf Bergenheim pisze:
Hello,
I have a DEM and a satellite image in GRASS of an island that I'd need
to create a 3D model for. Does anyone know how to get this data in 3DS?
I can use r.out.pov to create a tga file that POV-Ray is happy with, but
that doesn't create a 3D model... I've tried looking at blender, but I'm
not able to see any formats that seem to match directly.Any ideas?
--Wolf
Message: 4
Date: Thu, 21 Aug 2008 08:18:03 -0700
Subject: Re: [GRASS-user] common legend for the set of maps
To: grass-user@lists.osgeo.org
Message-ID: <AB6E60B2-EB3F-47C9-B662-DA819F4389ED@asu.edu>
Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yesMake sure that your are creating an FP map with float values rather than a cell map with integer values.
Second, your ranges overlap. They need to be non-overlapping to be meaningful in a legend. For example, a value of 0.7 could occur in all 3 of your ranges.
Michael
On Aug 21, 2008, at 4:53 AM, <grass-user-request@lists.osgeo.org> wrote:
Date: Thu, 21 Aug 2008 10:45:35 +0200
Subject: [GRASS-user] common legend for the set of maps
Message-ID: <48AD2B2F.1080203@amu.edu.pl>
Content-Type: text/plain; charset=ISO-8859-2; format=flowedHi
I have set of map with foolowing (example) ranges:
0.34-1.1
0.67-2.4
0.12-0.8And I need common legend for that set i.e 0.12-2.4
I think I shoud create map with range of data 0.12-2.4 and use it as the
source to the legend
I tried with r.plane and r.mapcalc but it is difficult to adjust proper
values
any ideas? (or simple solution?)
Jarek
------------------------------_______________________________________________
http://lists.osgeo.org/mailman/listinfo/grass-userEnd of grass-user Digest, Vol 28, Issue 62
