[GRASS-user] Re: grass-user Digest, Vol 30, Issue 46
Hi to all,
I can manage to install Grass into Ubuntu.
The trouble was that I was doing all steps in terminal with the active path is in desktop. We just need to move the current path from desktop to any other location (e.g. cd \d_drive) and do all the rest from the intrucsion found in the website. Things are going well then.
Thanks very much for all your help.
Tri Van
Quoting grass-user-request@lists.osgeo.org:
Send grass-user mailing list submissions to
  grass-user@lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-user digest..."
Today's Topics:
   1. Re: generalize a map of points (Wolf Bergenheim)
   2. Re: v.digit-grass64 (Martin Landa)
   3. Re: generalize a map of points (Wolf Bergenheim)
   4. Re: "Re: Contents of grass-user digest... HOW TO INSTALL
      GRASS" (Van PD Tri)
   5. Landsat SLC-Off gap filling (Ned Horning)
   6. Re: Landsat SLC-Off gap filling (maning sambale)
   7. Re: Landsat SLC-Off gap filling (Hamish)
   8. Re: examples of Web GIS interaction between citizens and
      governments (Eduardo corbelle)
   9. RE: How to install Grass into Ubuntu (Jhon Ortiz)
Message: 1
Date: Sun, 19 Oct 2008 23:46:00 +0300
Subject: Re: [GRASS-user] generalize a map of points
To: Jos? Mar?a Michia <jose.maria.michia@gmail.com>
Cc: grassuser <grass-user@lists.osgeo.org>
Message-ID: <48FB9C88.3000306@bergenheim.net>
Content-Type: text/plain; charset=ISO-8859-1
Jos� Mar�a,
If possible, I think it would be useful feature the following:
- Where two labels overlap, comparing an attribute to decide which one stays
For example: on a map of cities you can use the number of inhabitants.
If the city "A" has more inhabitants than the city "B", maintaining
the label of the city "A".
I have just now committed a change in v.label.sa that will do exactly
this. See the new overlap parameter. I would appreciate it if you could
test it, and give some feedback on how it is working for you.
Thank you,
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
Message: 2
Date: Sun, 19 Oct 2008 22:54:30 +0200
Subject: Re: [GRASS-user] v.digit-grass64
To: "Paolo Craveri" <pcraveri@gmail.com>
Cc: grass-user@lists.osgeo.org
Message-ID:
  <f8fe65c40810191354i4f22da31n95474e5edafe8168@mail.gmail.com>
2008/10/19 Paolo Craveri <pcraveri@gmail.com>:
there are differences, between wx and tcltk, in the manner of which
v.digit depicts isles: see images
http://picasaweb.google.it/pcraveri/Grass64Topology#
Is this normal ?
no;-)
well, both the TCL/TK and Wx digitizer seems to me to be buggy. TCL/TK
v.digit ignores boundaries which share two areas (shows them in green
by default), wx digitizer shows isles as areas (i.e. boundary sharing
area and isle as orange by defaut).
Please correct me if needed. Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Message: 3
Date: Mon, 20 Oct 2008 00:22:09 +0300
To: Markus Neteler <neteler@osgeo.org>
Cc: GRASS user list <grass-user@lists.osgeo.org>
Message-ID: <48FBA501.8080104@bergenheim.net>
On 19.10.2008 21:49, Markus Neteler wrote:
On Fri, Oct 17, 2008 at 10:19 PM, Wolf Bergenheim
<wolf+grass@bergenheim.net> wrote:
I'm still waiting for Hamish to check a patch for d.labels to allows
precision placement that v.label.sa. So far he has been to busy to check
it. *shrug*
Wolf, could you dig out the relevant link(s) or ticket?
Maybe we can accelerate things but I don't remember details.
I was too lazy to go digging through mail archives so I filed a ticket
instead (I never filed one for this issue, so I hope it's ok). The
ticket is number 340
http://trac.osgeo.org/grass/ticket/340
I also uploaded fresh patches (against the current develbranch_6).
Thanks for taking a look :slight_smile:
--Wolf
Message: 4
Date: Mon, 20 Oct 2008 12:51:31 +0700
Subject: Re: [GRASS-user] "Re: Contents of grass-user digest... HOW TO
  INSTALL GRASS"
To: Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>
Message-ID: <20081020125131.rn0id9a5cgc0c0ck@webmail.ctu.edu.vn>
Content-Type: text/plain; charset=UTF-8; DelSp="Yes"; format="flowed"
Hi to all,
Thanks Nikos!
I have just practised your guidance (i.e. > (a) You can launch grass
from a terminal by typing: grass -gui)
After doing it, the following error appear:
dtat@dtat-desktop:~$ grass -gui
The program 'grass' is currently not installed. You can install it by typing:
sudo apt-get install grass
bash: grass: command not found
I wonder why because I did run the command
And it looks like I was doing successful.
Could you please give me further help.
Best regards,
Tri Van
Quoting Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
On Mon, 2008-10-20 at 00:40 +0700, Van PD Tri wrote:
Hi to all,
I think I can install GRASS already. At the end, I receive a note like:
  │ Operating System Distributor License for Java v1.1 (DLJ)
  │ Operating System Distributor License for Java version 1.1 (DLJ)
  │ SUN MICROSYSTEMS, INC. ("SUN") IS WILLING TO LICENSE THE JAVA
PLATFORM ▒
  │ STANDARD EDITION DEVELOPER KIT ("JDK" - THE "SOFTWARE") TO YOU
ONLY UPON ▒
  │ THE CONDITION THAT YOU ACCEPT ALL OF THE TERMS CONTAINED IN
THIS LICENSE ▒
  │ AGREEMENT (THE "AGREEMENT"). PLEASE READ THE AGREEMENT
CAREFULLY. BY ▒
  │ INSTALLING, USING, OR DISTRIBUTING THIS SOFTWARE, YOU ACCEPT
ALL OF THE ▒
  │ TERMS OF THE AGREEMENT.
However, I have no idea where it is installed and how to launch
GRASS?! Could you please send any help?
Best regards,
Tri Van
Hi!
I don't think(=know if) that the "Java" message has anything to do with
GRASS.
(a) You can launch grass from a terminal by typing:
gass -gui
(b) Or you want to add a new menu item (Ubuntu specific: System >
Preferences > Main Menu > New Item -- then enter "grass -gui" withouth
the qiuotes in the "command" field, give some a name for your new
"launcher" and a description if you like. *** Decide under which Menu
you want/will place the "grass" launcher ***).
You might (...probably) want to read the following thread(s):
http://www.nabble.com/grass-gis-td19636258.html
http://www.nabble.com/grass-gis.-td19636354.html
Kind regards, Nikos
This message was sent using IMP, the Internet Messaging Program.
Message: 5
Date: Mon, 20 Oct 2008 02:11:21 -0400
Subject: [GRASS-user] Landsat SLC-Off gap filling
To: grass-user@lists.osgeo.org
Message-ID: <48fc2109.5de3.0@lightlink.com>
Content-Type: text/plain; charset="iso-8859-1"
Hi - Is there anyone out there who has worked on an algorithm to fill gaps in
Landsat ETM+ SLC-Off data? Now that the Landsat 7 archive is freely available
I am looking for an open source approach to fill the gaps in the SLC-Off data
and GRASS seems like a good option. I'm most interested in multi-date approaches
but at this stage I'm looking at single-date approaches as well. Any ideas?
Ned
Message: 6
Date: Mon, 20 Oct 2008 14:47:48 +0800
From: "maning sambale" <emmanuel.sambale@gmail.com>
Subject: Re: [GRASS-user] Landsat SLC-Off gap filling
To: nedh@lightlink.com
Message-ID:
  <f902f9840810192347s261337c2u418f410e1736cfe@mail.gmail.com>
+1
I had just downloaded new Landsat 7 SLC-Off data. It still useable
for land use change analysis. A grass tool would be very helpful.
cheers,
maning
in
available
data
approaches
Ned
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
Message: 7
Date: Mon, 20 Oct 2008 00:50:25 -0700 (PDT)
To: grass-user@lists.osgeo.org, nedh@lightlink.com
Message-ID: <771886.66278.qm@web110014.mail.gq1.yahoo.com>
Content-Type: text/plain; charset=us-ascii
in Landsat ETM+ SLC-Off data? Now that the Landsat 7 archive is freely
available I am looking for an open source approach to fill the gaps
in the SLC-Off data and GRASS seems like a good option. I'm most interested
in multi-date approaches but at this stage I'm looking at single-date
Some ideas here:
  http://grass.osgeo.org/wiki/MODIS#Removing_holes
both single scene interpolation (r.fillnulls) and rolling composite using a time series (r.patch) methods are explained.
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Message: 8
Date: Mon, 20 Oct 2008 09:59:03 +0200
From: "Eduardo corbelle" <eduardo.corbelle@gmail.com>
Subject: [GRASS-user] Re: examples of Web GIS interaction between
  citizens and governments
To: "M. Fioretti" <mfioretti@nexaima.net>
Message-ID:
  <276333290810200059p59d2b4aby8b12aa05f680b0c0@mail.gmail.com>
Marco:
If an owner wants to offer (enter) a parcel, he/she also can do it using the
web interface. In the same web (http://www.bantegal.com/sitegal ), the
fourth option on the left is "ofrecer parcelas" ("offer parcels"). Once
selected, this option guides you through several steps to locate the parcel
(you could try: just select a province, municipality and parish, click on
"seguir" --go on-- and a webmap will appear on which you can interactively
click on the parcel you would like to enter). A few more clicks on "seguir"
will show some cadastre information, a reference rent to be perceived (a
minimum of 20 euros a year or 10 euros per hectare-year), and other.
For a parcel to be correctly introduced in the system, the owner must
register (a registration page would appear near the end of the process).
Once the parcel is introduced, the administrative process is started and
several days later the owner would be required to sign a contract on paper.
By the way, some of the parcels already introduced in the system were
managed by the administration, and these were introduced by public
officials.
2008/10/18 M. Fioretti <mfioretti@nexaima.net>
On Fri, Oct 17, 2008 10:07:17 AM +0200, Eduardo corbelle wrote:
> Marco:
> Although it is not exactly what you asked for, I think the Galician Land
> Information System ( http://www.bantegal.com/sitegal ) recently created
in
> Spain deserves a look (unfortunately it doesn't have an English version).
Eduardo,
yes, thanks, this is an interesting use case. How do people or offices
who want to _lease_ unused lands to farmers enter those lands into the
system, and who are they? Are they only public officers?
       Marco
Your own civil rights and the quality of your life heavily depend on how
software is used *around* you: http://digifreedom.net/node/84
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081020/c19ef400/attachment-0001.html
Message: 9
Date: Mon, 20 Oct 2008 10:10:32 +0200
Subject: RE: [GRASS-user] How to install Grass into Ubuntu
To: <grass-user@lists.osgeo.org>, <vpdtri@ctu.edu.vn>,
  <giohappy@gmail.com>
Message-ID: <BLU145-W2333640710B2B284417899C62F0@phx.gbl>
The offical Ubuntu repositories are a bit outdated. A more updated
repo is the one from Jachym: http://www.les-ejk.cz/ubuntu/
The Gutsy one has Grass 6.3.0, updated to May 2008.
Im working with Ubuntu 7.10 Gutsy and in this repositories
not is available the version 6.3.0, the laster version in this
repositories is 6.2.2 (http://www.les-ejk.cz/ubuntu/).
The people who working in Ubuntu and want to work with
other version have to compile it. It's not a so hard task.
http://grass.osgeo.org/wiki/Compile_and_Install
If you want newer versions... you need to compile it. It's not a so
hard task, and we can give advices.
_________________________________________________________________
�Sigue el calor? Consulta MSN El tiempo
http://eltiempo.es.msn.com/
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081020/1507b616/attachment.html
End of grass-user Digest, Vol 30, Issue 46
