[GRASS-user] Re: grass-user Digest, Vol 31, Issue 69
Or use the zoom button menu on the display to set the display resolution to match the computational resolution
Michael
On Nov 30, 2008, at 12:05 AM, <grass-user-request@lists.osgeo.org> wrote:
Message: 8
Date: Sun, 30 Nov 2008 18:01:46 +1100
Subject: Re: [GRASS-user] maximum zoom-in reached
To: grass-user@lists.osgeo.org
Message-ID: <49323A5A.5030107@ozemail.com.au>
Content-Type: text/plain; charset=us-ascii
Message: 8 Date: Sun, 30 Nov 2008 08:02:14 +0530 From: H.S.Rai
<hardeep.rai@gmail.com> Subject: Re: [GRASS-user] maximum zoom-in
reached To: "GRASS user list" <grass-user@lists.osgeo.org> Message-ID:
<e46836620811291832h1a2e1d83j8f9ba2ca48b77260@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1 On Sat, Nov 29, 2008 at
8:34 PM, Maris Nartiss <maris.gis@gmail.com> wrote:
gis.m gives "Maximum zoom-in reached" error when display width/height
is smaller than one column/row. If You have data with higher
resolution, You have to adjust Your region settings (increase
resolution). See g.region how to set resolution.
Thanks to all for prompt and appropriate responses. Default region was
with resolution 1. I anticipated this and changed to .0001, but may be
I was not able to do it properly, and was not able to get zoom in.
Then I existing GRASS, restarted, and it worked fine.
$ g.region -p
projection: 1 (UTM)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 36.56820636
south: 6.09470106
west: 66.77269446
east: 98.66413062
nsres: 0.0001
ewres: 0.0001
rows: 304735
cols: 318914
cells: 97184257790
That's because the GIS manager and map display don't auto-update to new
location settings when you change them. They need to be reloaded.
However, you don't have to exit GRASS. If you change the region
settings, you can just close the GIS manager (this will close the map
display as well), and re-start it by typing gis.m <enter> at the terminal.
Richard
-- H.S.Rai
