[GRASS-user] Re: grass-user Digest, Vol 33, Issue 39
------------------------------ Message: 5 Date: Mon, 19 Jan 2009
12:00:08 +0100 From: Moritz Lennert <mlennert@club.worldonline.be>
Subject: Re: [GRASS-user] generating lines from points To: Martin
Landa <landa.martin@gmail.com> Cc: GRASS users list
<grass-user@lists.osgeo.org> Message-ID:
<49745D38.9030904@club.worldonline.be> Content-Type: text/plain;
charset=ISO-8859-1; format=flowed On 18/01/09 18:08, Martin Landa wrote:
> Hi,
> 2009/1/18 Martin Landa <landa.martin@gmail.com>:
>> The more lines you need to generate the longer list of categories will
>> be, not possible to give the list as the parameter. Then v.edit could
>> read categories from stdin, simillary to v.net.path. Hm, what about
>> v.net? New tool to generate network from points?
>> v.net input=points output=net operation=lines line_file=- << EOF
>> 1 1 2
>> 2 2 3
>> EOF
>> creates edges between points 1-2 and 2-3 with category 1 and 2?
> better
> v.net points=points output=net operation=net file=- << EOF
> 1 1 2
> 2 2 3
> EOF
> What do you think about that?
I think that a GRASS module for connecting lines between chosen points
is a definite yes (think of point coordinates of airports with
information about flight connections between airports). Up to now I've
been doing it with a simple script + v.in.ascii.
I think a module would be wonderful, since I've struggled with this task
a few times. Would it be rude to ask about your script, Moritz?
Richard
Not sure v.net is the most logical place to have this. Maybe a
stand-alone module v.points2lines ?
Moritz
Message: 6
Date: Mon, 19 Jan 2009 12:04:26 +0100
Subject: Re: [GRASS-user] Original location: Hot to create from the
  command line ?
To: peter.loewe@gmx.de
Cc: grass-user@lists.osgeo.org
Message-ID: <49745E3A.1000904@club.worldonline.be>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
On 19/01/09 10:47, peter.loewe@gmx.de wrote:
> Hi,
> is there an (easy) recipe to create a completely new location from
> scratch without using a GUI ?
> To be precise: If GRASS is started for the first time in "-text" mode
> (=no GUI) ** without having a sample location like Spearfish or North
> Carolina around**, how can location parameters (projection, extent,
> EPSG...) be handed over to set up a very first location ?
Just type in the name of the location you want to create and GRASS will
prompt you for the parameters.
Moritz
Message: 7
Date: Mon, 19 Jan 2009 12:06:56 +0100
  command line ?
To: Moritz Lennert <mlennert@club.worldonline.be>
Message-ID: <20090119110656.4810@gmx.net>
Content-Type: text/plain; charset="iso-8859-1"
> Moritz
That's true. But is there also a way to provide the parameters _without_ interaction with the user (-> GRASS scripting & automation) ?
Peter
-- Dr. Peter Lo"we <peter.loewe@gmx.de> Sensationsangebot verla"ngert:
GMX FreeDSL - Telefonanschluss + DSL fu"r nur 16,37 Euro/mtl.!*
http://dsl.gmx.de/?ac=OM.AD.PD003K1308T4569a
------------------------------ Message: 8 Date: Mon, 19 Jan 2009
12:23:37 +0100 From: Nikos Alexandris
<nikos.alexandris@felis.uni-freiburg.de> Subject: Re: [GRASS-user]
v.digit under wxGUI To: Vincent Bain <bain@toraval.fr> Cc: GRASS user
list <grass-user@lists.osgeo.org> Message-ID:
<1232364217.6974.0.camel@vertical> Content-Type: text/plain On Sun,
2009-01-18 at 19:30 +0100, Vincent Bain wrote:
> OK,
> so in order to fully enjoy the wxpython GUI on an 64 bit architecture
> (especially the wxdigit module) one should first read carefully the
> README file located in the your_grass_source_location/gui/wxpython
> directory.
> The section named "7 - VECTOR DIGITIZER" tells you to create a symbolic
> link to a wx library :
> sudo ln -s `locate _gdi_.so` /usr/local/lib/libgdi.so
> The command locate _gdi_.so may points towards the 32 bit library and
> ignore (?) the 64 bit libs path (/usr/lib64/...), so it fails. In my
> configuration I had to type :
> sudo ln -s /usr/lib64/python2.5/site-packages\
> /wx-2.8-gtk2-unicode/wx/_gdi_.so /usr/local/lib/libgdi.so
> And it worked !
Geat! Thanks :wink:
Message: 9
Date: Mon, 19 Jan 2009 11:36:07 +0000
Subject: Re: [GRASS-user] Original location: How to create from the
  command line ?
To: grass-user@lists.osgeo.org
Message-ID: <18804.26023.425982.30077@cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-ascii
> To be precise:
> If GRASS is started for the first time in "-text" mode (=no GUI) **
> without having a sample location like Spearfish or North Carolina
> around**, how can location parameters (projection, extent, EPSG...)
You can create a new location via the curses dialog, and specify
projection information interactively, but you can't use an EPSG code
here.
However, you can just provide bogus projection information at that
point, then correct it with "g.proj -c ..." once the startup is
complete.
-- Glynn Clements <glynn@gclements.plus.com>
------------------------------ Message: 10 Date: Mon, 19 Jan 2009
12:40:06 +0100 From: Nikos Alexandris
Landsat classification with CORINE CLC color codes? To: Markus Neteler
<neteler@osgeo.org> Cc: GRASS user list <grass-user@lists.osgeo.org>,
dimos_anastasiou@yahoo.com Message-ID:
<1232365206.6974.28.camel@vertical> Content-Type: text/plain On Mon,
2009-01-19 at 08:25 +0100, Markus Neteler wrote:
> On Mon, Jan 19, 2009 at 7:42 AM, Dimos <dimos_anastasiou@yahoo.com> wrote:
> > Hello,
> > My apologies if this question is already covered in this list...
> > 44 CORINE CLC RGB color codes are mentioned for each of the 44 land use
> > classes at:
> > http://dataservice.eea.europa.eu/download.asp?id=14234&filetype=.csv
> > Can we classify a Landsat RGB image based on these rgb color codes in
> > GRASS GIS and how?
> In my opinion it doesn't make much sense to use the RGB colors here
> since they are arbitrary (well, ok, ideally "close" to natural colors).
> What you can do:
> - download the related CORINE shape file(s)
> - extract training areas
> - run i.gensigset to generate statistics
> - run i.smap to do the classification
> - validate
> Markus
Hi! Markus suggestion is one solution.
I just want to add that, if you take samples (=areas) from CORINE (as
they are), they can be a bit rough to classify a, let's say, 15m
pixel-resolution Landsat satellite image. In my humble opinion, there is
no way in this case to completely avoid some manual digitisation of
training samples, or edit the samples you will extract from CORINE.
Well, it depends also on what (e.g. which land cover classes) you want
to extract from Landsat.
There is, on the web, a nice step-by-step which uses COREIN + i.smap on
Landsat [1].
Dimo, if you could be a bit more precise... ?
Kind regards, Nikos
[1] http://www.custom-scenery.org/Building-Scener.331.0.html
Message: 11
Date: Mon, 19 Jan 2009 14:02:04 +0200
Subject: Re: [GRASS-user] Landsat classification with CORINE CLC color
  codes?
To: Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>
Message-ID: <1232366524.2844.19.camel@uno>
Thanks for the great input!
I just want to create a high resolution land use map, based on an
already existing classification such as CORINE using Landsat data: I
will follow your instructions as below.
Regards, Dimos
On Mon, 2009-01-19 at 12:40 +0100, Nikos Alexandris wrote:
> > > Hello,
> > > classes at:
> > > GRASS GIS and how?
> > What you can do:
> > - validate
> > Markus
> Landsat [1].
> Kind regards, Nikos
grass-user mailing list
End of grass-user Digest, Vol 33, Issue 39
Richard,
(almost missed you question because of the digest subject line...)
On 20/01/09 05:10, Richard Chirgwin wrote:
I think that a GRASS module for connecting lines between chosen points is a definite yes (think of point coordinates of airports with information about flight connections between airports). Up to now I've been doing it with a simple script + v.in.ascii.
Now that Martin has implemented it in v.net, this is probably mostly hypothetical, but I just used very simple awk magic to massage point ascii data into lines. I.e. from an ascii file in the format of
StartX,StartY,EndX,EndY,LineCat
this command line creates the GRASS lines map:
awk -F"," 'BEGIN{i=0} {i++;print "L 2 1";print $1,$2,i;i++;print
$3,$4,i;print "1", $5 }' YourFile | v.in.ascii -n format=standard
out=YourMapName fs=" "
How to get to the input ascii file depends on your data setup, but I would use something like this (assuming you use a real db, have one map with points of which you would like to connect some and that you have a table called Connections in your db in the form of StartCat, EndCat, Value):
v.addcol PointMap col="x double precision"
v.addcol PointMap col="y double precision"
v.to.db PointMap option=coor
Then, some SQL to add StartX,StartY,EndX,EndY to your table Connections.
Then update your Connections table with something like:
UPDATE Connections SET StartX = PointMap.x, StartY=PointMap.y FROM PointMap
   WHERE StartCat=PointMap.cat
UPDATE Connections SET EndX = PointMap.x, EndY=PointMap.y FROM PointMap
   WHERE EndCat=PointMap.cat
And then extract the relevant values in an ascii file which you can then feed into the above awk line.
Moritz
