[GRASS-user] Re: grass-user Digest, Vol 35, Issue 25
On Mar 9, 2009, at 9:00 AM, <grass-user-request@lists.osgeo.org> wrote:
Date: Mon, 09 Mar 2009 10:59:35 +0100
From: Moritz Lennert <mlennert@club.worldonline.be>
Subject: Re: [GRASS-user] Modelling 1:n and m:n relationships in GIS
To: Benjamin Ducke <benjamin.ducke@oxfordarch.co.uk>
Cc: grass <grass-user@lists.osgeo.org>, qgis-developer
  <qgis-developer@lists.osgeo.org>, Users and Developers mailing list
  <gvsig_internacional@runas.cap.gva.es>
Message-ID: <49B4E887.9050405@club.worldonline.be>
Content-Type: text/plain; charset=UTF-8; format=flowed
On 09/03/09 00:00, Benjamin Ducke wrote:
Dear all,
I keep getting into situations where mapping 1:n and m:n relationships
in relational DBMS to GIS vector models becomes a problem.
The toughest restrictions of course are the 1:1 relation between map
features and attribute table records
Where do you see a 1:1 restriction ? In GRASS you can have several
features with the same category value, so related to one tuple in the
table and you can have several category values for one feature, so
related to several tuples in the table.
and the fact that GIS relates
data by spatial overlay, not foreign fields. I realize that some GIS
(like GRASS) are somewhat more flexible in that they can attach more
than one attribute table to a layer, but I am really looking for more
portable ways to deal with this.
- How do you deal with 1:n and m:n relations in GIS?
- What do you do if there are no spatial representations for the
records on the "n" side? Can that be handled at all?
Yes, the table you attach to your map can contain as many tuples as you
want for which there are no features in the geometry. You can even
attach a table to a map in which there is no tuple whatsoever related to
a feature.
Any ideas are very welcome, indeed!
It would help to have some concrete examples...
Moritz
Following up with Moritz, actually GRASS is very flexible in this regard. However, this flexibility is not very well known or understood by most users. Here are some of the main features.
1) Each vector object must have a category number (cat); that cat is a key field that links the object to a line (with corresponding key field, which may or may not be called "cat") in an attribute table. BUT cat does NOT have to be unique for each object. That is, more than one objects may have the same cat, such that you have a many:one relationship between vector objects and database entries.
2) Each vector object can have more than one "layer". Each layer represents a distinct connection to an attribute table. Each layer has its own cat series. So, for example, in layer 1, objects a,b,c,d, and e can all have cat=1 and link to a single line in the attribute table connected to the vector via layer one. In layer 2, the same objects can have cat=1 for a,b,c and cat=2 for d & e. Now, these objects are linked to 2 lines in a DIFFERENT table (or even the SAME table via a different connection and key field). That is, different layers can be joins between vector objects and distinct tables, or different kinds of joins between objects and the same table.
3) AFAICT, you are not prohibited from a situation where a single cat in the vector file (whether for one or many objects) can match as a key field with multiple lines in an attribute table, all of which have the same key field. However, I don't know how the data parses in that case.
4) Finally, the SQLite, PostgreSQL, and MySQL drivers are SQL compliant (dbf only partly), permitting complex joins between multiple attribute tables.
I hope this is helpful.
Michael
Dear all,
Moritz
This may be a bit hidden in vectorintro.html under Attribute management -> Categories. Although I have the suspicion that lengthy descriptions are not always read by a user, this (exceptional?) flexibility of the GRASS vector model could be emphasized a bit more under a separate heading, something like "Vector object IDs and relational DBMS", explaining that one vector object can have several IDs (categories) and several vector objects can share the same ID (category). The attribute table(s) connected to the vector can have entries for each category, but they must not have an entry for each category, similarly, the attribute table can hold information about categories not present in the vector. This is partially repeating what Michael wrote below. Maybe this is all redundant because it is already explained somewhere else, but I think vectorintro.html is a good place to hold all this information. Another suggestion would be that module manuals link to the vectorintro when appropriate. I know, the perfect user studies all intros first before using any module, and then first reads the manual for that module before using it, but IMHO this is unrealistic. At least I am not such a perfect user.
Markus M
Michael
grass-user mailing list
Good ideas!
Michael
______________________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Dear all,
Moritz
Markus M
Michael
Michael, Moritz,
thanks a lot for your clarifications.
These do indeed help. I must admit I never took the
time to really look into GRASS' DBMS management and
am impressed by it's flexibility now.
Thanks again,
Ben
----- Original Message -----
To: grass-user@lists.osgeo.org
Sent: Monday, March 9, 2009 5:42:23 PM GMT +01:00 Amsterdam / Berlin / Bern / Rome / Stockholm / Vienna
Subject: [GRASS-user] Re: grass-user Digest, Vol 35, Issue 25
Dear all,
relationships
you
related to
a feature.
Moritz
case.
attribute tables.
Michael
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
