On Jul 1, 2009, at 8:02 AM, grass-user-request@lists.osgeo.org wrote:
Date: Wed, 1 Jul 2009 06:16:52 -0700 (PDT)
Subject: Re: [GRASS-user] link to datasets from other locations?
To: grass-user@lists.osgeo.org
Message-ID: <1246454212138-3188925.post@n2.nabble.com>
Content-Type: text/plain; charset=us-asciihamish-2 wrote:
How do I link to a raster and vector data in another
location presuming it has the same projection?add the mapset as a symlink to the mapset in the other location,
then use the @othermapset notation.So sharing data between locations is not really supported?
Even if I just want to add the layer to the map view?Regards,
Timmie
An important concept behind locations is that all maps in a location share the same projection. Different locations can have different projections. With the exception of georectification, you can only display and manipulate maps from a single location during a working session. In this way you are guaranteed (well almost guaranteed) that all your maps will share the same projection and will overlay correctly.
Michael
