Hi Bulent,
I had a chance to mess around with the inverted DEM idea tonight. Here's what seemed to produce the best results for identifying peaks.
r.mapcalc 'inverted.DEM = -DEM'
Then I ran r.terraflow on the inverted DEM to get a filled, inverted DEM
r.terraflow elevation=inverted.DEM filled=terraflow.filled direction=<required> swatershed=<required> accumulation=<required> tci=<required>
(note that you will have to specify the other output maps too, even if you don't use them)
In the terraflow.filled map, I set the cells with value=0 to null (places where the flow went off the edge of the map).
Then I subtracted the filled map from the inverted DEM to find the sinks (=peaks of the original DEM)
r.mapcalc 'fill.difference =inverted.DEM-terraflow.filled'
If desired, these could then be inverted so that the larger the number, the closer to the peak.
r.mapcalc 'peaks = -fill.difference'
The result is draped over a relief map.
http://www.public.asu.edu/~cmbarton/files/temp/peaks_from_terraflow.jpg
Compare with the minic peaks map from r.param.scale
http://www.public.asu.edu/~cmbarton/files/temp/peaks.jpg
Michael
____________________
C. Michael Barton
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Nov 21, 2009, at 10:00 AM, grass-user-request@lists.osgeo.org wrote:
Date: Sat, 21 Nov 2009 07:01:37 -0700
Subject: [GRASS-user] inverting DEMs
To: grass-user@lists.osgeo.org
Message-ID:
<f3d3690d0911210601j2679db9bh91e39960a4eb9206@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"Hi,
I am trying to invert a DEM (i.e., make peaks basins and vice versa) but
there does not seem to be a module for this. I am assuming this can be done
through ' r.mapcalc ' which I have very limited experience.I also want to get ' r.prominence ' from the Add-ons site but the
text file is not downloadable. Should I copy and paste to create a text
file that contains the script?Thank you for all the suggestions,
