[GRASS-user] Re: grass-user Digest, Vol 46, Issue 11
Message: 6
Date: Thu, 4 Feb 2010 22:54:58 +0100
Subject: [GRASS-user] 3d vector file
To: "grass-user" <grass-user@lists.osgeo.org>
Message-ID: <KXC7JM$57548290A24594F3149AE9AD2A9AA743@libero.it>
Content-Type: text/plain; charset=iso-8859-1
starting from a 2d vector and using the v.extrude command i got a 3d vector, with the following settings:
zshift=0, hcolumn=a_level (the column where the topographic heights are written), type=line
the output 3d vector is regularly created and checking it with v.info i get at the very first line: B(OTTOM)=10 T(OP)=150 and also "map is 3d: yes ". Everything seems right!
Starting nviz anyway, my file is not 3d rendered...i would like to know if the file is really 3d and the problem is only about nviz, or if the file is just 2d...
I would like to know it, not because of the 3d rendering graphics, but mostly because i need to create a script that works on the third dimension of the vector file to get the height differences.
I don't know about the rendering, but regarding height a couple of possibilities occur.
But first: are you looking for height differences within the map, or compared to a second map?
If you're comparing attributes, you don't actually need to create a 3D map - you just need an attribute column that contains height. You can then use various vector modules.
Example (without knowing your exact problem): I have a map that contains spot heights, and I want each spot to contain (a) its own height and (b) the height of the nearest other spot. Map name in the example is Height. The spot elevation is contained in the column Elevation.
1. v.db.addcol Height columns="Near_Cat int,Near_Elevation double"
(This adds a column for the category and elevation of the nearest point)
2. g.copy vect=Height,Temp_Height
(This creates a second map you can use for v.distance)
3. v.distance -a from=Height from_type=point to=Temp_Height to_type=point upload=cat column=to_cat table=Height_Matrix
(Using the -a flag measures from all points, to all points, and stores the results in a table called Height_Matrix)
4. echo "update Height, Height_Matrix set Near_Cat=to_cat, where cat=from_cat" | db.execute
(This grabs the to_cat to use in the next query. Yes! There probably IS a neater way to do this but I have had weird faults from v.distance using the -a flag)
5. echo "update Height, Temp_Height set Near_Elevation=Elevation where Height.Near_cat=Temp_Height.cat" | db.execute
(Get the elevation of the nearest point back into the original map).
More information about your specific needs would be useful!
Richard Chirgwin
thanks a lot!!!
PS: any idea about a script that returns the height differences??? :slight_smile:
Matteo
