[GRASS-user] Re: grass-user Digest, Vol 50, Issue 75
Hi Folks,
Okay, through trial and error I figured it out. Lat Long coordinates entered into a SQLite data base should be entered as DOUBLE. I went over to decimal Lat Long and used negative instead of W. It came out fine. I used v.in.db to create a point vector. The only field types you can use as coordinates are INTEGER and DOUBLE. Since INTEGER cuts off the fraction (which can produce some peculiar point vectors) DOUBLE is what you need.
to used v.in.db you need to type "v.in.db table=name (whatever you name the table) driver=sqlite database=/Users/account/grassdata/LOCATION/MAPSET/named.db (You need the path to the database you created this is how I have it set up in OS X. In this case I stuck my target database in my MAPSET. I may do it elsewhere in the future) x=column with longitude y=column with latitude (I imaginatively used East and North) output=name of vector.
I haven’t played with the fields “z” or “where” yet.
If anyone has anything to add, feel free. There may be a more efficient way of doing it, but this worked.
Kurt
On Jun 29, 2010, at 12:00 PM, grass-user-request@lists.osgeo.org wrote:
Message: 6
Date: Tue, 29 Jun 2010 09:58:45 -0400
Subject: [GRASS-user] Re: grass-user Digest, Vol 50, Issue 73
To: grass-user@lists.osgeo.org
Message-ID: <1FFCD860-4138-4E08-965D-4ED755509A95@mac.com>
Content-Type: text/plain; charset=“us-ascii”
I am afraid I am using OS X and SQLite studio isn’t ready for OS X yet. GRASS 6.4 is the latest binary build thus far.
I still need to know the best field type for Latitude and Longitude coordinates.
Kurt
On Jun 29, 2010, at 2:37 AM, grass-user-request@lists.osgeo.org wrote:
Message: 8
Date: Tue, 29 Jun 2010 07:37:23 +0100 (BST)
From: Benjamin Ducke <benjamin.ducke@oxfordarch.co.uk>
Subject: Re: [GRASS-user] Entering point data with SQLite
To: GRASS user list <grass-user@lists.osgeo.org>
Message-ID:
<872729080.66359.1277793443836.JavaMail.root@mail.thehumanjourney.net>
Content-Type: text/plain; charset=utf-8
On 06/28/2010 09:52 PM, Kurt Springs wrote:
Also, I have been using SQLite Database Browser 1.3. It doesn’t place the rows of field names in the order they are created. In fact there seems to be no order at all and no way to rearrange the order.
I have found http://sqlitestudio.one.pl to be an extremely
useful open source solution for SQLite DB management.
Also, the author is very friendly and prompt to accommodate
wishes for additional functionality.
Have you considered simply using v.in.ogr/v.out.ogr to
manage the data in an external SQLite3 database?
Starting with GRASS 6.5.svn and GDAL 1.7, this should
work well.
Ben
As always, any help will be greatly appreciated.
Kurt
