[GRASS-user] Re: grass-user Digest, Vol 51, Issue 6
Dear Daniel,
I have a one-month-old (apologize) wingrass 6.4.svn installed from http://josef.fsv.cvut.cz/wingrass/ on windows7.
Date: Mon, 5 Jul 2010 17:11:39 -0300
From: Daniel Victoria [<daniel.victoria@gmail.com>](mailto:daniel.victoria@gmail.com)
[...] Opening a separate MSys console
and executing /grass/bin/grass64svn will start the Select location
window and after I click on Start, Grass crashes with the following
error:
$ grass64svn
Cleaning up temporary files ...
Starting GRASS ...
ATENÇÃO: Attention!
ATENÇÃO: Locking is not supported on Windows!
          __________  ___   __________    _______________
         / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
        / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
       / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
       \____/_/ |_/_/  |_/____/____/   \____/___//____/
Welcome to GRASS 6.4.0svn (2010)
GRASS homepage:                          [http://grass.osgeo.org/](http://grass.osgeo.org/)
This version running thru:               GNU Bash (Cygwin) (/usr/bin/bash.exe)
sounds like you are running through Cygwin (“GNU Bash (Cygwin) (/usr/bin/bash.exe)”) – on my machine the MSys desktop link triggers a welcome screen that at the same line says “Bourne Shell (/bin/sh)” (and everything works as expected including the wxpython GUI):
Starting GRASS ...
ATTENZIONE: Attention!
ATTENZIONE: Locking is not supported on Windows!
This version running thru: Bourne Shell (/bin/sh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.4>
Do you by any chance have Cygwin bash.exe on your %PATH% environmental variable?
As for the Python errors you mention, I am not sure but it may again be a problem related to %PATH% settings. It is indeed possible to have heritage Cygwin/GRASS and the new native Wingrass running on the same machine, but care must be taken to avoid messing with the global %PATH%.
As for running R from GRASS, an approach I have found useful is to follow the advice by Glynn Clements, i.e. not running GRASS from MSys but instead use a simple DOS box started via a batch file that sets required environmental variables to run GRASS, and then call the shell executable sh.exe (shell scripts designed for Cygwin/GRASS run with minimal adjustments – mostly to cope with MSys path conventions issues). Glynn has taken on this topic in a growing (thanks for your patience, Glynn!) number of posts – see for example:
http://osgeo-org.1803224.n2.nabble.com/grass-start-bat-in-windows-tp4492202p4492202.html
Finally, when I have my GRASS-enabled DOS box, I just type R (of course R needs to be in the %PATH%) and I am pretty much done.
I hope this helps and sorry if I misunderstood your questions,
Luigi
