Hi Hamesh,
Thanks for providing the information.
I have installed “Cygwin” and still am getting the same error Displaying that there is no such command. Can you explain more clearly what should i do to execute this command.
nani.
On Sun, Apr 3, 2011 at 6:00 PM, <grass-user-request@lists.osgeo.org> wrote:
Send grass-user mailing list submissions to
grass-user@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
grass-user-request@lists.osgeo.orgYou can reach the person managing the list at
grass-user-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-user digest…”Today’s Topics:
- Re: Problem with Python Scripts and grass.script (GRASS
6.5SVN) on Mac (Glynn Clements)- Re: Re: r.li.setup (Hamish)
- Re: Using r.buffer on image with geographic coordinates
(Markus Metz)
Message: 1
Date: Sat, 2 Apr 2011 23:37:47 +0100
Subject: Re: [GRASS-user] Problem with Python Scripts and grass.script
(GRASS 6.5SVN) on Mac
To: Johannes Radinger <JRadinger@gmx.at>
Cc: grass-user@lists.osgeo.org, Michael Barton
<Michael.Barton@asu.edu>
Message-ID: <19863.42299.525955.400396@cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-asciiJohannes Radinger wrote:
I tried to figure out the problem with william kyngesburye.
the script is also working on his mac. I saved the script in the bin
folder and ran in the GRASS terminal:AttributeError: ‘module’ object has no attribute ‘mapcalc’
What causes this AttributeError?
The grass.script module is either broken or very old (the mapcalc()
function was added in December 2008).From within GRASS, try the following:
$ python
import grass.script as grass
print grass.file
print grass.path–
Message: 2
Date: Sat, 2 Apr 2011 16:52:15 -0700 (PDT)
Subject: Re: [GRASS-user] Re: r.li.setup
To: grass-user@lists.osgeo.org, vinod kumar <nani.kunithi@gmail.com>
Message-ID: <235869.98585.qm@web110005.mail.gq1.yahoo.com>
Content-Type: text/plain; charset=iso-8859-1Nani wrote:
r.li.setup
How to install, Where to find it, how is it provided,r.li.* is not provided in WinGrass. Only on UNIX builds (Mac or
Linux). If you want to use these modules, you may also try the
Cygwin build of GRASS for MS Windows, or try the older r.le
modules.what is it supposed this command do.
see http://grass.osgeo.org/grass64/manuals/html64_user/r.li.html
Hamish
Message: 3
Date: Sun, 3 Apr 2011 15:07:47 +0200
From: Markus Metz <markus.metz.giswork@googlemail.com>
Subject: Re: [GRASS-user] Using r.buffer on image with geographic
coordinates
To: Ned Horning <horning@amnh.org>
Cc: GRASS user list <grass-user@lists.osgeo.org>
Message-ID: <BANLkTi=C5ETWZ0OH267Y3zQ3bvgrmB1kJw@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1On Wed, Mar 30, 2011 at 1:52 PM, Ned Horning <horning@amnh.org> wrote:
Thanks for the help compiling with v.buffer. I think I’m running the correct
version now but the function still does not complete properly. I pasted the
last several lines from the terminal screen below. I have a feeling I ran
out of memory. Any ideas about what I can try next?Not sure if the “d.vect: free(): invalid” error means that d.vect
caused the problem.You could try several things:
- update your grass-6.5 to r45873
- close the grass gui and other applications not really necessary
- now try v.buffer again
The process got killed while snapping boundaries which is rather
memory demanding. Memory consumption for vector operations like
snapping can be substantially reduced in grass 7, but grass 7 still
has only the broken version of v.buffer2 (to be fixed).Alternatively you could use r.grow.distance on the rasterized version
and set all values larger than the desired buffer distance to NULLMarkus M
D0/0: sa: 22
D0/0: current: 22
D0/0: current = 29, last = 30, lcount = 1
D0/0: sa: 28
D0/0: current: 28
D0/0: current = 29, last = 34, lcount = 1
D0/0: sa: 28
D0/0: current: 28
Building parts of topology…
Building topology for vector map …
Registering primitives…
1433691 primitives registered
119731336 vertices registered
Number of nodes: 1433605
Number of primitives: 1433691
Number of points: 0
Number of lines: 0
Number of boundaries: 1433691
Number of centroids: 0
Number of areas: -
Number of isles: -
Snapping boundaries…
Killed
GRASS 6.5.svn (NHD_Test):~ >GRASS 6.5.svn (NHD_Test):~ > *** glibc detected *** d.vect: free(): invalid
next size (normal): 0x0000000001a77fc0 ***
======= Backtrace: =========
/lib/libc.so.6(+0x775b6)[0x7f32f1a055b6]
/lib/libc.so.6(cfree+0x73)[0x7f32f1a0be83]
/usr/local/grass-6.5.svn/lib/libgrass_vect.6.5.svn.so(Vect_destroy_line_struct+0x28)[0x7f32f35be638]
d.vect(plot1+0xb0a)[0x40876a]
d.vect(main+0x1314)[0x4072d4]
/lib/libc.so.6(__libc_start_main+0xfd)[0x7f32f19acc4d]
d.vect[0x403cd9]
======= Memory map: ========
00400000-0040c000 r-xp 00000000 08:05 206108
/usr/local/grass-6.5.svn/bin/d.vect
0060b000-0060c000 r–p 0000b000 08:05 206108
0060c000-0060d000 rw-p 0000c000 08:05 206108
01a6a000-01a8b000 rw-p 00000000 00:00 0
[heap]
7f32e4000000-7f32e4021000 rw-p 00000000 00:00 0
7f32e4021000-7f32e8000000 —p 00000000 00:00 0
7f32e8b3c000-7f32e8b48000 r-xp 00000000 08:05 531120
/lib/libnss_files-2.11.1.so
7f32e8b48000-7f32e8d47000 —p 0000c000 08:05 531120
7f32e8d47000-7f32e8d48000 r–p 0000b000 08:05 531120
7f32e8d48000-7f32e8d49000 rw-p 0000c000 08:05 531120
7f32e8d49000-7f32e8d53000 r-xp 00000000 08:05 531542
/lib/libnss_nis-2.11.1.so
7f32e8d53000-7f32e8f52000 —p 0000a000 08:05 531542
7f32e8f52000-7f32e8f53000 r–p 00009000 08:05 531542
7f32e8f53000-7f32e8f54000 rw-p 0000a000 08:05 531542
7f32e8f54000-7f32e8f5c000 r-xp 00000000 08:05 527981
/lib/libnss_compat-2.11.1.so
7f32e8f5c000-7f32e915b000 —p 00008000 08:05 527981
7f32e915b000-7f32e915c000 r–p 00007000 08:05 527981
7f32e915c000-7f32e915d000 rw-p 00008000 08:05 527981
7f32e915d000-7f32e9160000 r-xp 00000000 08:05 523508
/lib/libgpg-error.so.0.4.0
7f32e9160000-7f32e935f000 —p 00003000 08:05 523508
7f32e935f000-7f32e9360000 r–p 00002000 08:05 523508
7f32e9360000-7f32e9361000 rw-p 00003000 08:05 523508
7f32e9361000-7f32e9371000 r-xp 00000000 08:05 134688
/usr/lib/libtasn1.so.3.1.7
7f32e9371000-7f32e9570000 —p 00010000 08:05 134688
7f32e9570000-7f32e9571000 r–p 0000f000 08:05 134688
7f32e9571000-7f32e9572000 rw-p 00010000 08:05 134688
7f32e9572000-7f32e958b000 r-xp 00000000 08:05 134634
/usr/lib/libsasl2.so.2.0.23
7f32e958b000-7f32e978a000 —p 00019000 08:05 134634
7f32e978a000-7f32e978b000 r–p 00018000 08:05 134634
7f32e978b000-7f32e978c000 rw-p 00019000 08:05 134634
7f32e978c000-7f32e97a2000 r-xp 00000000 08:05 531562
/lib/libresolv-2.11.1.so
7f32e97a2000-7f32e99a1000 —p 00016000 08:05 531562
7f32e99a1000-7f32e99a2000 r–p 00015000 08:05 531562
7f32e99a2000-7f32e99a3000 rw-p 00016000 08:05 531562
7f32e99a3000-7f32e99a5000 rw-p 00000000 00:00 0
7f32e99a5000-7f32e99a7000 r-xp 00000000 08:05 523515
/lib/libkeyutils-1.2.so
7f32e99a7000-7f32e9ba6000 —p 00002000 08:05 523515
7f32e9ba6000-7f32e9ba7000 r–p 00001000 08:05 523515
7f32e9ba7000-7f32e9ba8000 rw-p 00002000 08:05 523515
7f32e9ba8000-7f32e9baf000 r-xp 00000000 08:05 134268
/usr/lib/libkrb5support.so.0.1
7f32e9baf000-7f32e9dae000 —p 00007000 08:05 134268
7f32e9dae000-7f32e9daf000 r–p 00006000 08:05 134268
7f32e9daf000-7f32e9db0000 rw-p 00007000 08:05 134268
7f32e9db0000-7f32e9dd4000 r-xp 00000000 08:05 132675
/usr/lib/libk5crypto.so.3.1
7f32e9dd4000-7f32e9fd4000 —p 00024000 08:05 132675
7f32e9fd4000-7f32e9fd5000 r–p 00024000 08:05 132675
7f32e9fd5000-7f32e9fd6000 rw-p 00025000 08:05 132675
7f32e9fd6000-7f32e9fed000 r-xp 00000000 08:05 527976
/lib/libnsl-2.11.1.so
7f32e9fed000-7f32ea1ec000 —p 00017000 08:05 527976
7f32ea1ec000-7f32ea1ed000 r–p 00016000 08:05 527976
7f32ea1ed000-7f32ea1ee000 rw-p 00017000 08:05 527976
7f32ea1ee000-7f32ea1f0000 rw-p 00000000 00:00 0
7f32ea1f0000-7f32ea265000 r-xp 00000000 08:05 523504
/lib/libgcrypt.so.11.5.2
7f32ea265000-7f32ea464000 —p 00075000 08:05 523504
7f32ea464000-7f32ea465000 r–p 00074000 08:05 523504
7f32ea465000-7f32ea468000 rw-p 00075000 08:05 523504
7f32ea468000-7f32ea504000 r-xp 00000000 08:05 134182
/usr/lib/libgnutls.so.26.14.12
7f32ea504000-7f32ea703000 —p 0009c000 08:05 134182
7f32ea703000-7f32ea709000 r–p 0009b000 08:05 134182
7f32ea709000-7f32ea70a000 rw-p 000a1000 08:05 134182
7f32ea70a000-7f32ea717000 r-xp 00000000 08:05 132150
/usr/lib/liblber-2.4.so.2.5.4On 03/29/2011 03:00 AM, Markus Neteler wrote:
On Tue, Mar 29, 2011 at 8:27 AM, Markus Metz
<markus.metz.giswork@googlemail.com> wrote:
…If you ran make in the v.buffer directory and afterwards configure,
make and make install in /usr/local/src/grass6_devel, you would end up
with v.buffer2.
run configure, make, but not make install in
/usr/local/src/grass6_develrun make in the v.buffer directory, watch out for errors to make
sure it compiles all rightrun make install in /usr/local/src/grass6_devel, but not again
configure and/or makethat should give you the original v.buffer
An alternative: simply modify
vector/Makefile
to point to v.buffer and not v.buffer2…Markus
http://lists.osgeo.org/mailman/listinfo/grass-userEnd of grass-user Digest, Vol 60, Issue 5
