Hi Aldo, Martin
In last week I to did some work with adding scale/north to a map.
using 6.4.svn (a couple of days behind update at time of post).
With python wx GUI
Found similar to Aldo, where adding scalebar seemed to be a 'once-off'
option, couldn't click on it etc to edit. using icon on toolbar to open
'add scalebar' again didn't seem to help, I may have even crashed the
display/GRASS at one point by clicking around too much on that... but at
time was busy to print the map so did what I had to do to get job done
and continued.
Other bits I noticed, was if I chose to use print icon, and sent to pdf,
much of the map was a black box, with scalebar in top-left of black box
but positioned on right place of map. Black box though seemed to be this
huge bit of extra space associated with scalebar.
printing/exporting to .png image did not result in this black box.
Also, if I made a scalebar but then zoomed map in/out, the scalebar
stayed the same size and in the same position within the display window,
not in the same position relative to the map.
So whatever calculates the scalebar does not refresh if zoom is used
after creation of the scalebar.
Have not tried any of this back in tcltk GUI
Any aspects here worth verifying and adding to a bug report, or putting
in as their own bugs?
Aldo - let me know what bug # you have for putting yours in.
regards,
shane.
Message: 3
Date: Sat, 4 Feb 2012 12:09:47 +0100
Subject: [GRASS-user] Problems with histogram and scalebar in wxpython
GUI (GRASS6.4.2RC3)
To: <grass-user@lists.osgeo.org>
Message-ID: <059f01cce32d$81c6e1b0$8554a510$@clerici@unipr.it>
Content-Type: text/plain; charset="us-ascii"Dear GRASSusers and developers,
I'm using GRASS6.4.2RC3 under Fedora 16 and I'm having problems with the
wxpython GUI.1) In the 'Create histogram of raster map' function, the style pie and the
Color for text and axes options are not working.The options run fine on the tcltk GUI and in command line mode.
2) In the 'Add scalebar and north arrow', the scale can be modified only
once and the option can't be re-entered nor the scale can't be deleted.Also in this case there are no problems with the tcltk GUI.
Bugs or something wrong in my Python?
Many thanks in advance
A. Clerici
Parma University
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120204/a55a85be/attachment-0001.html------------------------------
Message: 4
Date: Sat, 4 Feb 2012 12:44:23 +0100
GUI (GRASS6.4.2RC3) (supplement)
Message-ID: <05aa01cce332$574b62d0$05e22870$@clerici@unipr.it>
Content-Type: text/plain; charset="us-ascii"In GRASS6.4.0 USB version I have the same problems with the histogram, but
"add scalebar" works fine.A. Clerici
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120204/03696e42/attachment-0001.html------------------------------
Message: 5
Date: Sat, 4 Feb 2012 13:36:48 +0100
Subject: Re: [GRASS-user] Problems with histogram and scalebar in
wxpython GUI (GRASS6.4.2RC3)
To: Aldo Clerici <aldo.clerici@unipr.it>
Cc: grass-user@lists.osgeo.org
Message-ID:
<CA+Ei1Oe25CoqmckGLQFAqXiLBFj-07eY-7SBo8b14R072K8qdw@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1Hi,
2012/2/4 Aldo Clerici <aldo.clerici@unipr.it>:
> Color for text and axes options are not working.right, wxGUI histogramming tool happily ignores any d.histogram
settings expect map name, see [1]. Please fill a bug report, I would
assume that this bug will be fixed for 6.4.3 (where wxGUI code base
will change).Martin
