Bonjour
Je ne parle pas anglais de ce fait je ne souhaite plus recevoir vos messages
Salutations
Daniel
De : “grass-user-request@lists.osgeo.org” grass-user-request@lists.osgeo.org
À : grass-user@lists.osgeo.org
Envoyé le : Jeudi 22 mars 2012 23h03
Objet : grass-user Digest, Vol 71, Issue 50
Send grass-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-user digest…”
Today’s Topics:
- Re: How Does GRASS Handle PostgreSQL Database Name Change?
(Rich Shepard) - v.out.ogr: Convert Attribute Database? (Rich Shepard)
(Helmut Kudrnovsky) - Re: Re: How Does GRASS Handle PostgreSQL Database Name
Change? (Rich Shepard) - Re: v.out.ogr: Convert Attribute Database? (Helmut Kudrnovsky)
- Re: SWAT Integration? (Chris George)
- Re: SWAT Integration? (Rich Shepard)
- Re: Re: v.out.ogr: Convert Attribute Database? (Rich Shepard)
- Re: Re: v.out.ogr: Convert Attribute Database? [SOLVED]
(Rich Shepard) - r.sun Direct/Diffuse problem (Collin Bode)
(Helmut Kudrnovsky)
Message: 1
Date: Thu, 22 Mar 2012 09:59:48 -0700 (PDT)
Subject: Re: [GRASS-user] How Does GRASS Handle PostgreSQL Database
Name Change?
To: grass-users@lists.osgeo.org
Message-ID:
<alpine.LNX.2.00.1203220956270.26933@salmo.appl-ecosys.com>
Content-Type: TEXT/PLAIN; charset=US-ASCII; format=flowed
On Thu, 22 Mar 2012, Maris Nartiss wrote:
As goes for a GUI crash, please, report it in the issue tracker, as WXGUI
shouldn’t crash if DB connection information isn’t correct.
Osgeo didn’t like something about my attempts to create an account so I
could post the problem. As it did not tell me what it didn’t like, I gave up
after a couple of attempts.
Context: trying to view the attributes of a vector map that apparently was
re-projected without the attributes following along. Results:
DBMI-Postgres driver error:
select * from fluvial where 1 = 0
ERROR: relation “fluvial” does not exist
LINE 1: select * from fluvial where 1 = 0
GRASS_INFO_ERROR(30342,1): Unable to describe table
GRASS_INFO_END(30342,1)
GRASS_INFO_ERROR(30345,1): Unable to describe table
GRASS_INFO_END(30345,1)
GRASS_INFO_ERROR(30425,1): Unable to describe table
GRASS_INFO_END(30425,1)
GRASS_INFO_ERROR(30428,1): Unable to describe table
GRASS_INFO_END(30428,1)
No more wxGUI.
Rich
Message: 2
Date: Thu, 22 Mar 2012 11:47:52 -0700 (PDT)
Subject: [GRASS-user] v.out.ogr: Convert Attribute Database?
Message-ID:
<alpine.LNX.2.00.1203221134070.26933@salmo.appl-ecosys.com>
Content-Type: TEXT/PLAIN; format=flowed; charset=US-ASCII
Trying to convert the attribute database of a vector (points) table from
dbf to postgres, and I’m missing a critical step.
Asked and answered:
GRASS 6.5.svn (Washington-Kinross):~/grassdata > v.db.connect
map=surface_h2o -p
Vector map surface_h2o@buckhorn is connected by:
layer <1> table <suface_water_sites> in database
</home/rshepard/grassdata/Washington-Kinross/buckhorn/dbf/> through driver
with key
Used v.out.ogr to export from dbf to a postgres table emulating the
example on the manual page:
The example’s syntax is:
Export to PostgreSQL/PostGIS
Export areas from GRASS vector map directly to PostGIS:
v.out.ogr input=polygons type=area
dsn=“PG:host=localhost dbname=postgis user=postgres”
olayer=polymap format=PostgreSQL
so I try,
GRASS 6.5.svn (Washington-Kinross):~/grassdata > v.out.ogr in=surface_h2o
type=point dsn=“PG:dbname=buckhornmine”
Exporting 13 geometries…
100%
v.out.ogr complete. 13 features written to <surface_h2o> (ESRI_Shapefile).
and end up with a directory called PG:dbname=buckhornmine/ containing the
shapefile.
What command line do I use to transfer the attributes from the native dbf
to a postgres table in the defined database?
Rich
Message: 3
Date: Thu, 22 Mar 2012 12:51:22 -0700 (PDT)
Subject: [GRASS-user] Re: How Does GRASS Handle PostgreSQL Database
Name Change?
To: grass-user@lists.osgeo.org
Message-ID: <1332445882579-4646223.post@n6.nabble.com>
Content-Type: text/plain; charset=us-ascii
But, for those of us attempting new operations a cross-reference to all
relevant modules (in this case attribute database related) would be
extremely helpful.
it seems it’s there, see the bottom of the manual page:
http://grass.osgeo.org/grass64/manuals/html64_user/db.connect.html
NAME
db.connect - Prints/sets general DB connection for current mapset and exits.
SEE ALSO
db.columns, db.drivers, db.login, db.tables, v.db.addtable, v.db.connect,
GRASS SQL interface
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-Does-GRASS-Handle-PostgreSQL-Database-Name-Change-tp4642201p4646223.html
Message: 4
Date: Thu, 22 Mar 2012 13:09:48 -0700 (PDT)
Subject: Re: [GRASS-user] Re: How Does GRASS Handle PostgreSQL
Message-ID: <alpine.LNX.2.00.1203221307230.3412@salmo.appl-ecosys.com>
NAME
SEE ALSO
Helmut,
Those are only for modules in the db.* family. What I meant by a cross
reference would include all the v.db.* modules, too. It did not occur to me
to look in the vector modules for ones related to database operations.
Rich
Message: 5
Date: Thu, 22 Mar 2012 13:35:22 -0700 (PDT)
Subject: [GRASS-user] Re: v.out.ogr: Convert Attribute Database?
Message-ID: <1332448522518-4646386.post@n6.nabble.com>
v.out.ogr - Converts GRASS vector map to one of the supported OGR vector
formats.
v.out.ogr export the entire vector map (geometry and attribute) not only the
attribute table
from the manual:
http://grass.osgeo.org/grass64/manuals/html64_user/v.out.ogr.html
missing format definition?
default format is shape-file
what I would do (a very lazy way):
- create a new mapset
- using db.connect (Prints/sets general DB connection for current mapset and
exits.) to define postgres as the mapset database backend - g.copy surface_h2o to the new mapset and the attribute table should be
automagically in the postgres
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/v-out-ogr-Convert-Attribute-Database-tp4645995p4646386.html
Message: 6
Date: Thu, 22 Mar 2012 16:45:48 -0400
Subject: Re: [GRASS-user] SWAT Integration?
To: Rich Shepard <rshepard@appl-ecosys.com>
Cc: grass-users@lists.osgeo.org
Message-ID: <4F6B8F7C.5000605@iist.unu.edu>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
There is an open source way to run SWAT, using the MWSWAT interface,
which uses MapWindow as the GIS system. You can get it from
www.waterbase.org.
Chris
On 19/03/2012 7:50 PM, Rich Shepard wrote:
About 10 years ago I tried integrating SWAT (Soil and Water Assessment
Tool, from Texas A&M Univ.) with GRASS-4.1. Didn’t work too well. Now I’d
like to use the most current version with GRASS-6.5svn.Is anyone here using SWAT?
(The source download link is broken but I’ll write to TAMU about this.)
Rich
Message: 7
Date: Thu, 22 Mar 2012 13:53:24 -0700 (PDT)
Message-ID: <alpine.LNX.2.00.1203221353020.3412@salmo.appl-ecosys.com>
On Thu, 22 Mar 2012, Chris George wrote:
There is an open source way to run SWAT, using the MWSWAT interface, which
uses MapWindow as the GIS system. You can get it from www.waterbase.org.
Chris,
Thank you.
Rich
Message: 8
Date: Thu, 22 Mar 2012 13:57:12 -0700 (PDT)
Subject: Re: [GRASS-user] Re: v.out.ogr: Convert Attribute Database?
Message-ID: <alpine.LNX.2.00.1203221355240.3412@salmo.appl-ecosys.com>
Helmut,
Er, looks like I did forget the format definition.
exits.) to define postgres as the mapset database backend- g.copy surface_h2o to the new mapset and the attribute table should be
I’ll give this a try. I can then delete the original map and copy the new
one back to the project mapset.
Will let everyone know how this works.
Rich
Message: 9
Date: Thu, 22 Mar 2012 14:00:51 -0700 (PDT)
[SOLVED]
Message-ID: <alpine.LNX.2.00.1203221359210.4587@salmo.appl-ecosys.com>
Sigh. Adding the format=PostgreSQL did the trick. Guess I needed more
caffine before lunch so as not to miss a critical option.
Again, many thanks,
Rich
Message: 10
Date: Thu, 22 Mar 2012 14:17:54 -0700
Subject: [GRASS-user] r.sun Direct/Diffuse problem
Message-ID: <61B99DE1-A89B-4127-A63E-08CC8EC2E09D@berkeley.edu>
I have a research site in Mendocino County, California where I have taken several months of insolation measurements using two Hukseflux LP02 black body Pyranometers. One is equiped with a shade ring. Measurements were taken in an open field with no topographic shading. Surrounding area is hilly and forested.
I have run r.sun for every week of the year, and compared the values that match my measurement times. The global radiation values match within 5%. However, the ratio of direct to diffuse radiation is off. r.sun is reporting 20-22% diffuse radiation, while the field measurements are reporting 7-10% diffuse.
I am using Linke Turbidity Index values from www.helioclim.org, which look too high. However, when I tried arbitrarily changing the Linke Turbidity index and rerunning r.sun, I could get the diffuse/direct ratio to match field values, but then the global radiation was much too high.
Am I missing a parameter to help with this? Any suggestions would be appreciated.
Collin
Message: 11
Date: Thu, 22 Mar 2012 15:03:48 -0700 (PDT)
Name Change?
Message-ID: <1332453828046-4646675.post@n6.nabble.com>
SEE ALSO
? v.db.addtable, v.db.connect, … see above ;o) …
… it’s open source :o) … concrete suggestions for improvements are
welcomed…
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-Does-GRASS-Handle-PostgreSQL-Database-Name-Change-tp4642201p4646675.html
End of grass-user Digest, Vol 71, Issue 50
