[GRASS-user] Re: GRASS-user] Help with reprojection
On Jan 2, 2009, at 4:38 PM, <grass-user-request@lists.osgeo.org> wrote:
Message: 2
Date: Fri, 2 Jan 2009 21:04:44 +0200
Subject: [GRASS-user] Help with reprojection
To: grass-user@lists.osgeo.org
Message-ID:
  <bf69017a0901021104n29f77efal2206f53128b08435@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
I'm new to GRASS, and am having trouble with reprojection. I've spent
two days trying to figure this out, and I feel that I'm close, but
reprojection is still failing. Could anyone clue me in what I'm
missing?
The input data set is Natural Earth II map of the world
<http://www.nacis.org/data/NE2/NE2_WDB1.jpg&gt; 16200x8100 JPG in plate
carrée projection. I need to reproject it into Lambert azimuthal
equal-area projection centered on N0 E15. I'm using WinGRASS 6.3.0.
First, I've created GRASS location "geographic" with following region
and projection:
g.region -p
projection: 99 (Equidistant Cylindrical (Plate Caree))
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 8100
south: 0
west: 0
east: 16200
nsres: 1
ewres: 1
rows: 8100
cols: 16200
cells: 131220000
g.proj -p datumtrans=0
PROJ_INFO-------------------------------------------------
name : Equidistant Cylindrical (Plate Caree)
datum : wgs84
towgs84 : 0.000,0.000,0.000
proj : eqc
ellps : wgs84
a : 6378137.0000000000
es : 0.0066943800
f : 298.2572235630
lat_0 : 0.0000000000
lat_ts : 0.0000000000
lon_0 : 0.0000000000
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1.0
I then imported the JPG map, which got split into color channels and
composed the channels together into single map.
After, I created a new location "lambert":
g.region -p
projection: 99 (Lambert Azimuthal Equal Area)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 8100
south: 0
west: 0
east: 16200
nsres: 1
ewres: 1
rows: 8100
cols: 16200
cells: 131220000
-PROJ_INFO-------------------------------------------------
name : Lambert Azimuthal Equal Area
datum : wgs84
proj : laea
ellps : wgs84
es : 0.0066943800
f : 298.2572235630
lon_0 : 15.0000000000
x_0 : 0.0000000000
y_0 : 0.0000000000
unit : meter
units : meters
meters : 1.0
Finally, when I try reprojection I get "Input raster map is outside
current region" error:
r.proj input=NE2 location=geographic mapset=PERMANENT method=cubic
Input Projection Parameters: +proj=eqc +lat_0=0.0000000000
+lat_ts=0.0000000000 +lon_0=0.0000000000 +a=6378137 +rf=298.257223563
+no_defs +towgs84=0.000,0.000,0.000
Input Unit Factor: 1
Output Projection Parameters: +proj=laea +lat_0=0.0000000000
+lon_0=15.0000000000 +x_0=0.0000000000 +y_0=0.0000000000 +a=6378137
+rf=298.257223563 +no_defs +towgs84=0.000,0.000,0.000
Output Unit Factor: 1
Input raster map is outside current region
How can I make this work?
Your problem is that this map is an image, not a GIS map. It is in what is called an xy "projection" in GRASS. That is, it is in no projection at all. The coordinates of each cell are simply the xy coordinates from the corner, not their position in the world.
In a 'real' GIS map, each cell would have some kind of real-world geographic coordinates (latlon, UTM, etc).
To get from a graphic image like this to geospatial data, you need to georectify the map. It would be a good idea for you to get an intro GIS book so that you can understand what is going on with this if it is unfamiliar to you.
The steps you need to follow in GRASS are...
1) create an xy location
2) import your jpg map into the xy location
3) open GRASS in your Lambert location
4) start the georectifier and georectify the map from the xy to Lambert location.
Looking at the jpg, it has no latlon or other geographic markers. This will make it difficult to georectify accurately. If you are looking for nice geospatial data of world topography, it might be better for you to download some data rather than trying to georectify a jpg image. GTOPO30 or similar scale (1km or larger) topography can be downloaded from a variety of places. Check the GRASS site to links to geospatial data. Also check out the GLCF <http://glcf.umiacs.umd.edu/ >. For global-scale imagery, try MODIS satellite data. The good thing about these data sets is that they are already georectified and can be imported directly into GRASS as GIS data. You can then easily reproject to something else.
Michael
Alex Bernstein:
this data needs a lat/lon location.
perhaps with wgs84 datum or no datum with a spherical ellipsoid?
(at this scale maybe it doesn't matter much; for reprojection a datum
will be needed)
> rows: 8100
> cols: 16200
north-south:
8100/(90+90) = 45 pixels per degree, ie a resultion of 1'20".
east-west gives the same answer. (180W to 180E is 360deg)
I think you will either need to make a "world file" for the .jpg before
importing with r.in.gdal into the lat/lon location, OR:
- create a simple xy location
    (lat/lon location will not allow north > 90, and you image while
     still not geo-referenced will go to 8100)
- run r.region to set n,s,e,w bounds to 90,-90,180,-180
- run g.setproj to rejig the location into a lat/lon one.
- check resolution is correct (nicely "0:01:20") with r.info.
- zoom to area of interest. you probably do not want to reproject
  entire planet. after zooming check resolution is preserved,
  (g.region -p, maybe with "g.region res=0:01:20 -a" after zoom to fix)
  and run "r.mapcalc cropmap=fullmap" to perform the crop.
then from the lambert location run r.proj to pull the cropped image
across.
there are some examples of this process in the GRASS wiki, look at the
"Global datasets" page.
Michael:
accurately.
with some guesswork you can figure it out: extent is full planet and
rows/cols of map are exact multiples of deg-min-sec.
happy new year,
Hamish
(now back to the beach :wink:
    (lat/lon location will not allow north > 90, and your image while
umm, that might not work -- r.info will still know the map is XY even
if the location is changed to lat/lon.
cropped image across.
look at the "Global datasets" page.
the above issue should be covered there; also check the mailing list
archives.
so your "easiest" solution is to create a "world file". see the GDAL
JPG or GeoTiff format import page, or do a web search for instructions.
Hamish
