I wonder if it is having trouble with your paths. They have spaces and "(" in them, and are not quoted.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sep 6, 2011, at 9:00 AM, <grass-user-request@lists.osgeo.org> <grass-user-request@lists.osgeo.org> wrote:
Date: Tue, 06 Sep 2011 13:44:14 +0200
Subject: Re: [GRASS-user] Re: [GRASS-windows] WinGRASS Python 2.7
To: Glynn Clements <glynn@gclements.plus.com>
Cc: grass-user@lists.osgeo.org, grass-windows@lists.osgeo.org
Message-ID: <20110906114414.92440@gmx.net>
Content-Type: text/plain; charset="utf-8"Hi again,
sorry for posting again, but somehow I can't get it work to
run GRASS GIS using my local Python 2.7 installation.
See comments below:-------- Original-Nachricht --------
Datum: Mon, 5 Sep 2011 01:57:38 +0100
Von: Glynn Clements <glynn@gclements.plus.com>
An: "Johannes Radinger" <JRadinger@gmx.at>
CC: grass-user@lists.osgeo.org, grass-windows@lists.osgeo.org
Betreff: Re: [GRASS-user] Re: [GRASS-windows] WinGRASS Python 2.7Johannes Radinger wrote:
As recommended I did the changes.
I just tried to first disable the PYTHONHOME and
GRASS_PYTHON. The lines in the env.bat file are now:rem Path to the python directory
rem set PYTHONHOME=%GISBASE%\Python25
rem if "x%GRASS_PYTHON%" == "x" set GRASS_PYTHON=pythonis that correct?
I tried at this step to start GRASS but it doesn't work
anymore. Nothing is started!! So it seems that this isn't
working! Maybe I have to set the path to python.org in the
env.bat, but I don't know how the lines should look like.For the GUI, setting e.g.:
set GRASS_PYTHON=c:\Program Files (x86)\Python27\pythonw.exe
should suffice.
So what I tried now were three different settings in the env.bat
1)
set GRASS_PYTHON=C:\Program Files (x86)\Python27\pythonw.exein this case: GRASS is starting using the Python25
2)
set GRASS_PYTHON=C:\Program Files (x86)\Python27\pythonw.exein this case: Nothing is started!
3)
set C:\Program Files (x86)\Python27
Just to inform you why I need that: I wrote a .py script (including g.parser elements) which I want to call inside GRASS with "file.py" (like any other modules e.g. r.fuzzy etc.) The script is working (tested on my Mac using GRASS in combination with Python 2.7)! The script calls scipy which can only be used in combination with Python 2.6 or newer (so far as I remember).
So hopefully this issue can be solved as soon as possible as I want to use the script also on my windows-office computer!!
Thank you
Johannes
