[GRASS-user] Re: [GRASSLIST:1212] zoom in different monitor?
[note the mailing list moved away from Baylor more than a year ago]
Duffy, Garret wrote:
Apologies if this seems trivial but I was wondering if anyone knows how
to have the zoomed portion of a raster appear in another monitor, say x1
instead of x0?
d.zoom changes the region for the entire session, so you have to save the
region before opening a new monitor and then reload the saved region once
you switch back to the original monitor. The same applies to display
frames created with d.frame (nice for inlaid overviews).
d.mon x0
d.rast
d.zoom
g.region save=original
d.mon x1
d.rast
d.zoom
d.mon x0
g.region original
you might also play around with i.points/i.vpoints multi window zooming.
I seem to recall someone wrote an addon script for this, check the wiki
and mailing list archives.
Hamish
instead of x0?
You can very easily do this in the GIS Manager GUI where each map display has independent zoom levels.
Moritz
