[GRASS-user] Re: grassuser Digest, Vol 11, Issue 55
grassuser-request@grass.itc.it wrote:
Message: 1
Date: Sat, 24 Mar 2007 17:24:46 -0400
Subject: [GRASS-user] Postgresql/postgis making databases
To: grassuser@grass.itc.it
Message-ID: <372DA460-DD8A-4C6D-8796-9317D9F94EFF@mac.com>
Content-Type: text/plain; charset=US-ASCII; delsp=yes; format=flowed
Hi folks,
I have finally gotten postgresql and postgis installed along with pgadm3 on OS X 10.4.9, which leaves me at the point of "What Now?"
Keep in that my familiarity is with Filemaker and Access, which, I am sure every one will agree, are fairly "turn key" as the old expression goes. Potgresql is another matter. I need someone's help get to the next step. I believe passwords and permissions need to be sorted out, then In need to create my data bases. I will need to create tables, categories, populate the databases, and be able to edit the information. Also, I need to be able to move the database file(s) from my desktop to my laptop. Step by step instructions would be best.
I am planning on starting work on my PhD research this summer, and would like to use postgresql/postgis to create and maintain my archaeological database.
Anyone's help would be appreciated.
I'll try, although I am also relatively new to this.
First you'll need to get your connection sorted out. In Grass, this is in the db.Connect and db.Login modules (in the Mac interface, this is under the Databases menu item, Manage Databases).
In db.Connect, use Connect to Database to open the appropriate interface. Check the Postgres instructions in the Wiki here:
*http://grass.ibiblio.org/grass61/manuals/html61_user/pg.html
*This will show you what the Postgres interface expects for database name and host identification. If you're using the GUI, do *not* put quote marks around your hostname, driver, etc. If you are using a local database, then you will have host=localhost
Then use Login to Database for username and password.
Use db.tables -p to see if you're connected - you will get a list of tables in the "Output" panel if it's worked.
You will need to decide what you intend to store in Postgres, and how to connect it to mapping data. I'm still working on this, so regrettably I can't help here. Trying to associate population data with map regions is doing my head in ... If you have any suggestions I'd love it!
A final thought about database connections.
If you've imported maps (for eg, from MapInfo vector files, etc), then they will probably be stored in local dbf files. If you're using some local files and some Postgres files, then you need to swap your connect and login between the two.
In particular, this means remembering that the local login is:
driver=dbf
database name: $GRASSFILES/$LOCATION_NAME/$MAPSET/dbf/
This is *not* intuitive and is not explained anywhere in particular! ...And also: if you have set a schema parameter for Postgres (don't know if you need to) then in the swap back to local, you need to clear this connection. Put a space into the Database Schema panel in the GUI to clear the schema to null.
Richard C
Message: 2
Date: Sat, 24 Mar 2007 16:30:05 -0500
Subject: Re: [GRASS-user] 'where' sql command in d.vect and others
Message-ID: <87odmie3du.fsf@patagonia.sebmags.homelinux.org>
Content-Type: text/plain; charset=us-ascii
On Sat, 24 Mar 2007 12:05:05 -0500,
Seb <spluque@gmail.com> wrote:
However, the same doesn't work within the display manager with, for
instance, d.vect. In that case, the 'where' parameter ends up within
braces in the actual call.
Some more fiddling led me to find out the correct syntax in display
manager:
str_3='"W Arctic"'
which creates a valid sql query and the map plots correctly. However,
this runs into another problem with d.out.file from a display of the
queried map and says:
Sorry <Arctic'> is not a valid option
Could this be a bug? If the 'where' statement does its job with this
string, I would have expected d.out.file to work too.
