[GRASS-user] Re: highest and lowest point in catchment
grass-user-request@lists.osgeo.org wrote:
Send grass-user mailing list submissions to
  grass-user@lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-user digest..."
Today's Topics:
   1. highest and lowest point in catchment (Dr. Manuel Seeger)
   2. SHELL Variable problem: Workaround (Peter L?we)
   3. Re: SHELL variable not set (Martin Wegmann)
   4. Re: SHELL variable not set (Glynn Clements)
   5. Re: SHELL variable not set (Hamish)
   6. Re: SHELL variable not set (Markus Neteler)
   7. Re: Building wxgrass vdigit (Martin Landa)
   8. segment_format error with r.watershed (Wes Kent)
   9. union features of vector (Alfredo Alessandrini)
  10. Re: Snap across layers (Martin Landa)
Message: 1
Date: Tue, 29 Jan 2008 10:01:20 +0100
Subject: [GRASS-user] highest and lowest point in catchment
To: GRASSLIST <grass-user@lists.osgeo.org>
Message-ID: <479EEB60.6050606@uni-trier.de>
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
Hello all,
I hope the questions does not seem too simple, but I have now no real good idea how to solve this simple problem:
I need to find the highest and the lowest point within catchments WITH their coordinates (and to get the information about altitude and coordinates, of course)
thanks for hints!
manuel
Manuel - hope I'm not being silly here, but I'd consider just using an SQL select directly to the data store.
Select max( <altitude column> ), <latitude column>, <longitude column>, <any other column you want> from <table> where <boundary conditions of catchment>
Select min( <altitude column> ), <latitude column>, <longitude column> <any other column you want> from <table> <boundary conditions of catchment>
If you have to, you could extract only the catchment to a separate vector, so that you don't need to fool around with complex boundary conditions.
But I'm sure that a genuine Grass expert will have a simpler solution than this ...
Richard
Thanks Richard,
but elevation data is on a raster map.
The idea I had was to generate point vector files with the highest and lowest point and then generate the colums with y and y coordinates... but it seems to me like a complicated way and I was wondering if there is a possibility to do that with r.mapcalc.... I think the functions are ther, but how combining?
Perhaps someone knows a way?
Thanks
MAnuel
Today's Topics:
Message: 1
Hello all,
thanks for hints!
manuel
Richard
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent Scientific Assistant
Physische Geographie Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften Geography/Geosciences
Universität Trier University of Trier
D - 54286 Trier
Tel.: +49-651-201 4557
Fax: +49-651-201 3976
Web: http://www-neu.uni-trier.de/index.php?id=9607
Maybe something like this...
For each catchment you run r.info -r to get the highest and lowest
value of the DEM (use a MASK for the catchment and r.info -r DEM).
Then, with r.mapcalc you select the highest and lowest areas that you
obtained with r.info. After that you can vectorize the areas selected
and do v.db.update to get coordinates.
It would be nice to put this all into a script if you have too many catchments.
One problem would be that you might not get a single pixel for the
high and low parts of the basin. It could be a small area...
Another thing. v.rast.stats can give you the max and min value for a
DEM for every catchment. It just wont give you the coordinates - not
that I know of...
Good luck
Daniel
On Jan 30, 2008 5:03 AM, Dr. Manuel Seeger <seeger@uni-trier.de> wrote:
Thanks Richard,
Thanks
MAnuel
>> Today's Topics:
>> Message: 1
>> From: "Dr. Manuel Seeger" <seeger@uni-trier.de>
>> Hello all,
>> thanks for hints!
>> manuel
> catchment>
> conditions.
> than this ...
> Cheers,
> Richard
Dr. Manuel Seeger
D - 54286 Trier
Just another (incomplete) idea!
(a) Here "r.stats -ng" to get pixel values with coordinates (?) and
export in file (like x,y,z)
(b) Do a numeric sort (sort -n) according to z value
sort -n -k3 input_file.txt | tail -1 #### this is from
http://lists.osgeo.org/pipermail/grass-user/2008-January/042520.html
(c) Instead of only tail -1 grab both "head -1" (that would be the min)
and "tail -1" (that would be the max) and so you have one "min" and one
"max" even if you have small areas
and then the rest... (?)
that I know of...
Good luck
Daniel
> Thanks Richard,
> Thanks
> MAnuel
> >> Today's Topics:
> >> Message: 1
> >> Hello all,
> >> thanks for hints!
> >> manuel
> > catchment>
> > conditions.
> > than this ...
> > Cheers,
> > Richard
> Dr. Manuel Seeger
> D - 54286 Trier
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
