I solved the problem when I set the resolution explicitly instead of relying on the defaults in the QGIS interface, when setting the region to subset.
I am typing the commands in a GRASS shell called from the GRASS tools menu,
and attach my steps following p91 of the book. Any suggestions appreciated!Thanks
Brendon Wolff-Piggottuser@USER-5F22862413 /c/documents and settings/user/grassdata/rsa/geographic
$ g.region “region=ecoast”Please post
g.region region=ecoast -p
to understand at which resolution you create the new map (if not the
original res.).user@USER-5F22862413 /c/documents and settings/user/grassdata/rsa/geographic
$ r.mapcalc “srtm_ecoast=srtm_rsa”GRASS_INFO_ERROR(804,1): Unable to close raster map
GRASS_INFO_END(804,1)possilby you have nanometer resolution and try to generate a XXGB file?
Disk full?Markus
