You can run HEC-RAS, 1-D flow model, freeware, only available for windows (Gods bless virtual machines) and then you can use r.inund.fluv (grass addon) to spread the simulation result upon the DEM. Note that in order to use HEC-RAS you need measures of the river sections.
HTH
Margherita
Anyone know of 1-, 2-, or 3-D hydraulic flow models that can be integrated
with GRASS?
Rich
Eng. Margherita Di Leo
Ph.D. Candidate
Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata Campus Macchia Romana
85100 - Potenza Italy
Margherita,
Hm-m-m. I have an old VMware guest with win98se that I can run on
virtualbox. Don't know if the HEC series will run on that version of
Microsoft.
Margherita,
Since it will also run under wine I need to learn how to unpack the
installation .exe ... unless that's what wine acts upon.
