[GRASS-user] Re: Import global maps (Ascii, png or KLM) from riverthreat.net
On 16/08/2011 5:00 pm, grass-user-request@lists.osgeo.org wrote:
Message: 5 Date: Mon, 15 Aug 2011 12:30:28 +0300 From: Micha Silver <micha@arava.co.il> Subject: Re: [GRASS-user] Re: Import global maps (Ascii, png or KLM) from riverthreat.net To: Johannes Radinger <JRadinger@gmx.at> Cc: grass-user@lists.osgeo.org Message-ID: <1313400628.8806.4.camel@SL6> Content-Type: text/plain; charset="UTF-8" On Mon, 2011-08-15 at 10:24 +0200, Johannes Radinger wrote:
> Hello again!
> > Just to follow up my last weeks question:
> Is there anyone who can help me how to import a map from
> riverthreat.net? What are the appropriate settings of the
> coordinate system? and how do I have to import the raster
> maps? For more info just see email below.
I tried with the ASCII formatted data and it works fine using the GRASS
r.in.arc module. Here are the steps:
Create a GRASS location based on the EPSG:4326 coordinate reference
system, and set its region to the whole world, with resolution 0.5 deg:
  g.region e=180 w=-180 n=90 s=-90 res=0.5 -p
Download the ASCII file. I had to make one small change in the ARC/Info
headers: the NOVALUE number should be an integer, so just change it to
-9999 (instead of -9999.00000).
Now:
r.in.arc Pesticide_Loading.asc out=pesticide
and display the resulting raster.
Micha
Import with r.in.gdal doesn't require the files to be modified, e.g.:
r.in.gdal input=Biodiversity_Threat.asc out=Biodiversity_Threat -o
Josh.
