[GRASS-user] Re: Importing Dems with r.in.xyz
Hanlie Pretorius wrote:
> I don't think it's this bug because this bug discards only one line of
> data. I don't get any data in because the number of coordinate pairs
> in the file is less than the number of cells in the defined region.
Markus Metz:
Weird. In 6.4, r.in.xyz does import a file where the number of
coordinate pairs is far less than the number of cells in the defined
region. (I just did a simple test with two input lines and a region
with 26.5 million cells, got clean import and correct result)
sorry, I'm not really grasping what the problem is. If you suspect
there is something weird going on can you make the .xyz.bz2 file
available for me to download, and supply the output of r.univar
`wc -l` and `r.in.xyz --verbose`?
Hamish
2010/6/7, Hamish <hamish_b@yahoo.com>:
Markus Metz:
Hamish
Ok, the text file (6.1MB compressed) that I use as input to r.in.xyz
is available at:
http://www.nedbib.za.net/dems/
Output of r.in.xyz --verbose:
Reading data ...
Writing to map ...
r.in.xyz complete. 0 points found in region.
Output of r.univar:
total null and non-null cells: 1146474
total null cells: 1146474
Of the non-null cells:
n: 0
minimum: -nan
maximum: -nan
range: -nan
mean: -nan
mean of absolute values: -nan
standard deviation: -nan
variance: -nan
variation coefficient: -nan %
sum: 0
output of wc -l:
1146370
Output of r.info:
| Layer: dem_2728ab_25m Date: Mon Jun 7 12:09:34 2010
| Mapset: PERMANENT Login of Creator: hanlie
| DataBase: /media/0847147784/grassdata
| Title: Raw x,y,z data binned into a raster grid by cell mean ( dem_2728
| Timestamp: none
| Type of Map: raster Number of Categories: 255
| Data Type: FCELL
| Rows: 1011
| Columns: 1134
| Total Cells: 1146474
| Projection: Transverse Mercator
| N: -49312.5 S: -74587.5 Res: 25
| E: -2987512.5 W: -3015862.5 Res: 25
| Range of data: min = -nan max = -nan
| Data Source:
| /media/0847147784/data/CD-NGI/DEMS/25m dems/2728/ab/2728AB.ort.grass
| Data Description:
| generated by r.in.xyz
| Comments:
| r.in.xyz input="/media/0847147784/data/CD-NGI/DEMS/25m dems/2728/ab/\
| 2728AB.ort.grass" output="dem_2728ab_25m" method="mean" type="FCELL"\
| x=1 y=2 z=3 zscale=1.0 percent=100
Thanks
Hanlie
g.region -p
north: -49312.5
south: -74587.5
west: -3015862.5
east: -2987512.5
nsres: 25
ewres: 25
rows: 1011
cols: 1134
cells: 1146474
From the region settings you posted previously, I assume that the 1.
column is north and the 2. is east, so:
r.in.xyz input=2728AB.ort.grass output=2728AB.ort fs=, x=2 y=1
r.in.xyz complete. 1146370 points found in region.
r.univar map=2728AB.ort
total null cells: 104
n: 1146370
minimum: 1473.52
maximum: 1618.85
range: 145.33
mean: 1519.76
mean of absolute values: 1519.76
standard deviation: 26.6106
variance: 708.125
variation coefficient: 1.75098 %
sum: 1742202717.5849609375
Everything looks ok.
Markus M
On Mon, Jun 7, 2010 at 12:33 PM, Hanlie Pretorius
Markus Metz:
Hamish
is available at:
Reading data ...
Writing to map ...
Output of r.univar:
n: 0
minimum: -nan
maximum: -nan
range: -nan
mean: -nan
variance: -nan
sum: 0
output of wc -l:
1146370
Output of r.info:
| Timestamp: none
| Data Type: FCELL
| Rows: 1011
| Columns: 1134
| Data Source:
| Data Description:
| Comments:
Thanks
Hanlie
2010/6/7, Markus Metz <markus.metz.giswork@googlemail.com>:
g.region -p
north: -49312.5
south: -74587.5
west: -3015862.5
east: -2987512.5
nsres: 25
ewres: 25
rows: 1011
cols: 1134
cells: 1146474
n: 1146370
minimum: 1473.52
maximum: 1618.85
range: 145.33
mean: 1519.76
variance: 708.125
Markus M
Ahh, you have found the error. In fact, the columns should not be
swopped, the region specifications should. I've retried the import and
it works now despite the missing data and the DEM sits in the right
place compared to the rest of my data. Thanks for everyone's help and
my apologies for the confusion.
Our national projection swops X and Y and reverses the direction of
the positive coordinates, so it can get very confusing.
Hanlie
