[GRASS-user] Re: Importing lines from database
Seb wrote:
Is this still the best solution for creating lines from a
points ASCII file? So assuming one has an ASCII file like:
---<--------------------cut
here---------------start------------------->---
id|X|Y
AGB-08-0001|-4.44|22.06
AGB-08-0001|-5.90|20.17
AGB-08-0001|-5.03|17.49
AGB-08-0001|-5.03|18.16
AGB-08-0002|-4.44|22.06
AGB-08-0002|-5.90|20.17
AGB-08-0002|-5.03|17.49
AGB-08-0003|-4.44|22.06
AGB-08-0003|-5.90|20.17
here---------------end--------------------->---
and we'd like to create lines for each code in the "id" column, we'd
have to reformat the file so that it conforms to the "standard" GRASS
format for ASCII lines files? If so, it seems we'd also need to recode
such an "id" column into integer, so that it can be used as category.
Or perhaps there is a better approach to importing this kind of data
that are typical in animal tracking studies, where coordinates
correspond to measurements taken at sequential times for each animal
(id)? Thanks in advance for any input.
it's pretty easy to get that into 'v.in.mapgen -f' format, but attaching
the labels might be a pain so maybe the awk script (if you can get your
head around it) is easier way after all??.
here's a little script to do it:
# script to load in data file, then make into lines based on unique
# first column
INFILE="animal_track.dat"
OUTFILE="animal_track.asc"
MAPNAME=`echo "$OUTFILE" | cut -f1 -d.`
ANIMALS=`grep ^AGB "$INFILE" | cut -f1 -d'|' | sort | uniq`
echo "nan nan" > "$OUTFILE"
\rm "${OUTFILE}.table"
i=0
for CRITTER in $ANIMALS ; do
   i=`expr $i + 1`
   grep -w "$CRITTER" "$INFILE" | \
     awk -F'|' '{print $2 " "$3}' >> "$OUTFILE"
   echo "nan nan" >> "$OUTFILE"
   echo "$i|$CRITTER" >> "${OUTFILE}.table"
done
v.in.mapgen -f in="$OUTFILE" out="${MAPNAME}_import"
v.category in="${MAPNAME}_import" out="$MAPNAME" option=add
g.remove vect="${MAPNAME}_import"
v.db.addtable "$MAPNAME" column="label varchar(25)"
## slow
while read LINE ; do
   CAT=`echo "$LINE" | awk -F'|' '{print $1}'`
   LABEL=`echo "$LINE" | awk -F'|' '{print $2}'`
   v.db.update map="$MAPNAME" column=label value="$LABEL" where="cat = $CAT"
done < "${OUTFILE}.table"
## or, faster
sed -e "s/^/INSERT INTO $MAPNAME (cat,label) values (/" \
    -e "s/|/,'/" \
    -e "s/$/');/" "${OUTFILE}.table" | db.execute
# another fast, but how to correctly quote ''?
awk -F'|' -v MAPNAME=$MAPNAME \
  '{print "INSERT INTO " MAPNAME " (cat,label) values (" $1 ",\'" $2 "\');" }' \
# all done
hopefully not too badly linewrapped by yahoo's helpfulness.
ok, still not very simple, but given free-form input data it is hard
to tell the computer what you want.
Hamish
On Fri, 29 May 2009 10:20:33 -0700 (PDT),
Hamish <hamish_b@yahoo.com> wrote:
Seb wrote:
Is this still the best solution for creating lines from a points
here---------------start-------------------> ---
id> X|Y
AGB-08-0001> -4.44|22.06 -5.90|20.17 -5.03|17.49 -5.03|18.16
AGB-08-0002> -4.44|22.06 -5.90|20.17 -5.03|17.49
AGB-08-0003> -4.44|22.06 -5.90|20.17
here---------------end---------------------> ---
recode such an "id" column into integer, so that it can be used as
category. Or perhaps there is a better approach to importing this
kind of data that are typical in animal tracking studies, where
coordinates correspond to measurements taken at sequential times for
each animal (id)? Thanks in advance for any input.
attaching the labels might be a pain so maybe the awk script (if you
can get your head around it) is easier way after all??.
# script to load in data file, then make into lines based on unique #
first column
INFILE="animal_track.dat" OUTFILE="animal_track.asc" MAPNAME=`echo
ANIMALS=`grep ^AGB "$INFILE" | cut -f1 -d'|' | sort | uniq` echo "nan
nan" > "$OUTFILE" \rm "${OUTFILE}.table"
i=0 for CRITTER in $ANIMALS ; do i=`expr $i + 1` grep -w "$CRITTER"
"$INFILE" | \ awk -F'|' '{print $2 " "$3}' >> "$OUTFILE"
   echo "$i|$CRITTER" >> "${OUTFILE}.table" done
v.in.mapgen -f in="$OUTFILE" out="${MAPNAME}_import" v.category
in="${MAPNAME}_import" out="$MAPNAME" option=add g.remove
## slow while read LINE ; do CAT=`echo "$LINE" | awk -F'|' '{print
$1}'` LABEL=`echo "$LINE" | awk -F'|' '{print $2}'` v.db.update
map="$MAPNAME" column=label value="$LABEL" where="cat = $CAT" done <
"${OUTFILE}.table"
## or, faster sed -e "s/^/INSERT INTO $MAPNAME (cat,label) values (/"
\ -e "s/|/,'/" \ -e "s/$/');/" "${OUTFILE}.table" | db.execute
# another fast, but how to correctly quote ''? awk -F'|' -v
MAPNAME=$MAPNAME \ '{print "INSERT INTO " MAPNAME " (cat,label) values
(" $1 ",\'" $2 "\');" }' \ "${OUTFILE}.table" | db.execute
# all done
Excellent! I think I might have cooked something similar to what you
suggest, without using v.in.mapgen, as I'm not familiar with MATLAB
vector output (beyond what the help page says):
---<--------------------cut here---------------start------------------->---
# Locate line start and end (store in file having: beg end n id)
cut -d"|" -f1 locs | uniq -c | \
    awk 'NR > 1 {++n0; n1+=$1; print n0 + 1, n1 + 1, $1, $2; n0=n1}' \
    > locs_id_lbrks
# Create the standard file and import to GRASS
while read beg end n id; do
    awk -F"|" -v beg="${beg}" -v end="${end}" -v n="${n}" -v id="${id}" \
  'BEGIN {printf "L %s\n", n}
         NR >= beg && NR <= end {print $2, $3}' locs
done < locs_id_lbrks | v.in.ascii -n out=test format=standard
---<--------------------cut here---------------end--------------------->---
where the id column could be removed from locs_id_lbrks and the 'while'
loop for simplicity. However, I was stuck dealing with categories and
keep the ID strings so that info is not lost, and now I see how you did
that!
Thanks so much,
Seb
id> X|Y
first column
"${OUTFILE}.table"
# all done
So IIUC, it's not possible to keep attributes for each point along a
lines vector, so that one can select points along a line that meet
certain criteria. For example, to be able to show (or do calculations)
a line joining points that are have values "A" in column 3 and values
"Z" in column 4. Thanks.
Seb
ASCII file?
In grass7, you also have 'v.net ... operation=arcs' (thanks to Martin Landa) to which you feed an existing points file and a file with the following information:
[category of edge] [category of start node] [category of end node]
Hasn't received much testing I think, but if it does, it could probably be backported to grass6.5.
Moritz.
