[GRASS-user] Re: intersection of vectors not working (fixed but some issued remain)
So, I managed to get the intersections of contours with drainages. But
not the way I wanted at first. If I just derive the contours and
drainage, I don't get the intersections. If I export them as
shapefiles and import again, then I get intersections...
Carlos
On 7/23/06, Carlos Guâno Grohmann <carlos.grohmann@gmail.com> wrote:
Hi all.
I'm trying get the intersections of contours and drainage, bu v.clean
insn't giving me any output.
The contours are from r.contour.
Drainages came from JGrass (I need Strahler order), I used r.mapcalc
to get a raster only with the orders of interest, then r.thin, then
r.to.vect.
After that I patched the vectors, with v.patch and used v.clean to get
the intersections, as:
v.clean input=patch output=temporary err=intersect tool=break
but then...
GRASS_INFO_MESSAGE(10017,11): Tool: Break lines at intersections
Intersections: 0
Intersections: 0 (line 329)
Intersections: 0 (line 683)
Intersections: 0
I don't understand. Did I miss something on generating contours or
converting drainage to vector? I used v.build on both maps prior to
v.patch.
thanks
Carlos
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
_________________
