[GRASS-user] Re: [Live-demo] Updating the software
Firman Hadi wrote:
I have downloaded the LiveDVD and installed it
as Virtual Machine using VMWare.
I want to install another package, gftp, so I have to
'apt-get update' but there is an error
reaching http://mirror.math.ucdavis.edu, which is
written in /etc/apt/sources.list
I did remove the site from the sources list, added another
server to the sources list and managed to install gftp.
that's fine, any standard debian mirror will do.
UC Davis was used simply because that's where our ISO builder is
near and the ISO takes hours to build so we wanted something fast...
But when I do this there is a warning that some of the
package need to be remove (using apt-get autoremove).
I am afraid if I do the autoremove it will break the
dependent packages of original LiveDVD package.Is
there any mirror?
I don't think it has anything to do with the mirror.
As I understand it the autoremove packages do not appear because
the debian mirror has changed, but rather that the locally installed
package which sucked it in automatically is no longer there & the
local apt database doesn't think it's needed anymore. As the LiveDVD/VM
compiles some packages by hand it's generally better to err on the
side of having a little bit of cruft around rather than to remove
a package which might be needed by a custom installed program.
probably the easiest solution is to just 'apt-get install' all the
packages it says it wants to remove. In general *-dev packages could
be safely removed, but probably not lib* packages.
have fun,
Hamish
have fun,
Hamish
That is correct, any ubuntu mirror will work. If you open the Synaptic
Package manager (System->Administration->Synaptic Package Manager)
and go to the Settings -> Repositories, then select "Other from the drop
down list there's actually a button to automatically find the best
server for your location based on ping times. I highly recommend using
this to find the closest mirror to you.
Alex
PS: I'll email the system administrators to find out why the ucdavis
mirror went down, thanks for reporting.
