[GRASS-user] re: Mac OSX- How slow can you go?
Macsurfcat wrote:
I am running _OSX.5.6_ on an _intel_ _Mac_ using two (2)
duo-core processors and a bunch of memory. I have set up
GRASS 6.3 and it seems to be especially sluggish; i.e.,
literally all night to import a vector shapefile, albeit a
substantial one.
does the shapefile contain a rather long detailed polyline, like a
coastline? if so search the mailing list archives for the "florida
coastline" problem.
at which stage does it stall? building lines?
In addition, many modules (commands) will execute and then force an
exit from the application, requiring a re-launch. Curiously, the
tasks themselves are often completed.
that is not normal. are any error messages available?
by "application" you mean all of GRASS quits? Does it give you a "someone
is already using this mapset" error when you try to start GRASS again?
The "brand" is *OpenOX Grass*, an "it requires no additional
dependencies" package.
If there are build problems with that, we might be able help guess what
the problem is, but it is likely you will have to report problems
directly to OpenOSX as they do their building/packaging separately.
Hamish
Just a little command ...
I am using the binaries from William Kyngesburye on a MacBook Pro 2Ghz Dual Core with 2G RAM (GRASS 6.3). Have used the ones from Lorenzo as well. After installing the framework packages everything worked very well so far ...
Harald
substantial one.
coastline" problem.
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
Harald Hofmann PhD Candidate - Hydrogeology School of Geosciences
Bldg 28 Monash University Clayton Campus Wellington Road VIC 3800
Australia
harald.hofmann@sci.monash.edu.au
Office: +61 3 9905 5786
Fax: +61 3 9905 4903
