Johannes,
Looking at your Python code and the error, I expect the issue is with the way you are calling the script, rather than it’s content.
From the documentation, g.parser returns a Python dictionary. The options “command” is a variable, rather than a function.
http://grass.osgeo.org/grass64/manuals/html64_user/g.parser.html
The key error occurs when you attempt to access a key, in your case upstream_shreve, when it does not exist.
http://wiki.python.org/moin/KeyError
I suspect the problem is that you’re not setting a value for upstream_shreve from the command line, i.e.,
./test3.py upstream_shreve=newmapname upstream_part=upstreammap shreve=anothermap
In your Python script, if you throw in:
print options
You’ll be able to quickly check it contains the key-value pairs you expect.
Hope this helps,
Josh.
On 3 Feb 2011, at 16:55, "Johannes Radinger" <JRadinger@gmx.at> wrote:
-------- Original-Nachricht --------
Datum: Thu, 3 Feb 2011 16:26:47 +0000
Von: Joshua Arnott <josh@snorfalorpagus.net>
An: "grass-user@lists.osgeo.org" <grass-user@lists.osgeo.org>
Betreff: [GRASS-user] Re: mapcalc problem in python script!!
Johannes,
way you are calling the script, rather than it's content.
"command" is a variable, rather than a function.
I suspect the problem is that you're not setting a value for
shreve=anothermap
print options
You'll be able to quickly check it contains the key-value pairs you
expect.
Hope this helps,
Josh.
Hello Josh,
first thank you for looking over my code...
Sr but I don't know what you're meaning excactly... the print options command gives me {}... but how should the executable .py file look like?
/johannes
If {} is all that is returned, it means the dictionary is empty. How are you running your Python script? What do you type at the grass command prompt?
Josh.
