[GRASS-user] RE: Network Analysis output in GRASS
Donald wrote:
I am returning to GRASS after a 10 year hiatus and I must
say that I am impressed !
I am working on some simple network analysis (road
distances from a point) and want the output to appear as
concentric rings. I think I need to use v.net.iso on
my road network but it appears from the manual that
the output from v.net.iso is a line file. I'd like to
push that out to a polygon to get concentric rings so it
looks like I need a few more processing steps.
Like I said, it has been a long while since my GRASS4.0/4.1
days - what would people suggest using to push the output of
v.net.iso out to a polygon ? v.surf.idw, v.surf.icw,
v.hull ? Aren't these all point interpolations and I
need to interpolate from lines ?
perhaps "v.to.db option=start/end" to get endpoints and then
string them together into a new vector line or run v.hull?
or similarly but with 'v.to.points -n'.
getting the line vertex order right might be a pain.
v.hull isn't the best as it cuts across "bays" in the blob, but
other than manual approaches (like above or digitizing by hand
around the lines with v.digit then snapping to underlying vertices), I'm not sure. Keen to hear any other solutions though.
Hamish
