Hi Artem,
I am trying to compile the osm2pgsql.c using Msys in win2k (to be used for winGRASS) and the following is part of the list of errors. I have put both the libxml/ xmlstring.h and libxml/ xmlreader.h files into the same directory as the one with osm2psql.c in. What seem to be the problem here? Where should I put my libxml.dll and why is the compiler not recognise these files?
error*********************************
libxml/ xmlstring.h: No such file or directory
libxml/ xmlreader.h: No such file or directory
parse error before "reader"
In function: 'StartElement':
'xmlChar' undeclared (first use in this function)
Any advice and suggestions is much appreciated. Many thanks
best regards
Casey Wong
To: "yuri bay" <ksh_wong@msn.com>
Subject: Re: [OSM-talk] How to convert OSM into GML - stuffs installed
Date: Tue, 6 Feb 2007 13:54:28 +0000Yes, you should be able to compile osm2pgsql in win32. You'll need libxml.dll
( try gnuwin32 on sourceforge).
ArtemOn Tuesday 06 February 2007 10:49, yuri bay wrote:
> Artem,
> By the way I also have these installed:
> 1) Postgresql/postgis
> 2) MinGW
> 3) Msys
> 4) winGRASS
> Many thanks
> regards
> Casey
> >From: Artem Pavlenko <artem@pavlenko.uklinux.net>
> >CC: talk@openstreetmap.org
> >Subject: Re: [OSM-talk] How to convert OSM into GML - examples needed
> >Date: Tue, 6 Feb 2007 09:37:32 +0000
> >Casey,
> >I'm assuming you're on a Linux box and you have postgresql/postgis
> >installed
> >(see http://www.postgresql.org http://www.postgis.org for howto)
> >1. Get the source
> >svn co http://svn.openstreetmap.org/utils/osm2pgsql
> >2. cd ./osm2pgsql
> > make
> > ( You might have to modify Makefile to fit your settings)
> >3. ./osm2pgsql planet.osm > planet.sql
> >You can then load planet.sql into postgresql :
> >psql -Uusername dbname < planet.sql
> >4. I dont use GRASS myself but I'm pretty sure it would let you connect to
> >postgis db and load osm data. You can also use ogr2ogr utility to convert
> >postgis table into something else e.g shapefiles . Just google for
> > gdal/ogr
> >Cheers
> >Artem
> >On Tuesday 06 February 2007 09:13, yuri bay wrote:
> > > Artem,
> > > Many thanks for your reply. I am very interested to learn more, would
> >you
> > > mind letting me know more detail about the step involves, for instance,
> > > where do I go to load OSM into postgresql/postgis, I mean where do I
> > > put the file osm2pgsql.c and what do I do with it? And then how /
> > > where do
> >I
> > > read it into GRASS. Sorry but I am newbie in this and your help is
> > > much appreciated!
> > > Best Regards
> > > Casey
> > > >To: talk@openstreetmap.org
> > > >CC: "yuri bay" <ksh_wong@msn.com>
> > > >Date: Mon, 5 Feb 2007 18:23:18 +0000
> > > >You can load planet.osm into postgresql/postgis with osm2pgsql.c
> > > >Then read direclty into Grass or export to GML/KML/Shapefiles whatever
> > > >using
> > > >PostGIS native functionality or ogr2ogr
> > > >Cheers
> > > >Artem
> > > >On Monday 05 February 2007 17:37, yuri bay wrote:
> > > > > Hi,
> > > > > Does anyone know where can I find examples on how (i.e. the steps
> > > >involve
> > > > > in) to convert OSM into GML? Is this the best way to import OSM
> >into
> > > > > GRASS? I am using WinGRASS on win2k. I have the OSM dataset
> > > >(planet.osm)
> > > > > but not sure what to do with it. How can I start to convert it
> > > > > into
> > > >GML?
> > > > > Do I need any other software, script editor or programming language
> > > > > such
> > > >as
> > > > > C ? Your help is much appreciated.
> > > > > Regards
> > > > > Casey Wong
> > > > > _________________________________________________________________
> > > > > MSN Hotmail is evolving check out the new Windows Live Mail
> > > > > http://ideas.live.com
> > > Click Here To Find Your Perfect Match This Valentines!
> > > http://msnuk.match.com/
Get Hotmail, News, Sport and Entertainment from MSN on your mobile. http://www.msn.txt4content.com/
