Just found the problem with PostgreSQL-import:
If the postGIS-layer has multiple geometries (in my case, centroid and polygon), it will be viewed with “db.tables -p”, but not imported through “v.in.ogr”. Error is misleading as it says “Layer not available”. Workaround, was a copy of the layer with only one geometry. Would be great to be able to select though, e.g. as done in QGIS.
patrick
Message: 4
Date: Wed, 14 Mar 2012 10:50:57 +0100
From: "Patrick S." [<patrick_GIS@gmx.ch>](mailto:patrick_GIS@gmx.ch)
Subject: [GRASS-user] postgreSQL import
To: grass mailing list [<grass-user@lists.osgeo.org>](mailto:grass-user@lists.osgeo.org)
Message-ID: [<4F606A01.6050504@gmx.ch>](mailto:4F606A01.6050504@gmx.ch)
Content-Type: text/plain; charset="iso-8859-1"
I try to import various files from PostgreSQL to GRASS in GRASS70.
db.connect driver=pg
database='host=<server>,dbname=<database>,schema=<schamename>'
db.login user="sustaincity" pass="+++"
db.connect -p
db.tables -p |less
for i in {1..3};
do
v.in.ogr dsn='PG:host=<servername> dbname=<dbname>
user=<username>' layer=schema.layer output=layer$i
type=boundary,centroid -o --o;
done/
This does only work for few layers. Some layers have many items inside
and these are not recognized, although I can view them through db.tables
-p.:
*/ERROR: Layer <schema.layername> not available/*
any ideas?
