[GRASS-user] Re: ppa for grass 7 Ubuntu Quantal
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Forgotten to cc to list
Rainer
- -------- Original Message --------
Subject: Re: [GRASS-user] ppa for grass 7 Ubuntu Quantal
Date: Mon, 25 Mar 2013 18:44:25 +0100
Reply-To: Rainer@krugs.de
To: Rashad M <mohammedrashadkm@gmail.com>, Rainer@krugs.de
On 25/03/13 17:24, Rashad M wrote:
yes. there is. unbuntugis-testing PPA
I found ubuntugis-testig, but it only goes up to precise - I am looking for quantal.
Don't worry for now - I just compiled GRASS.
Rainer
I am maintaining it but since I was on travel. I couldnt update the build. Currently finishing
the "job" thing and I will update the packages most probably by tomorrow
On Mon, Mar 25, 2013 at 9:51 PM, Rainer M Krug <r.m.krug@gmail.com
<mailto:r.m.krug@gmail.com>> wrote:
Hi
I lost the overview and can't find it via google:
is there a ppa for GRASS 7 for Ubuntu Quantal or do I have to compile myself?
Rainer
_______________________________________________ grass-user mailing list
grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
-- Regards, Rashad
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJRUI1QAAoJENvXNx4PUvmC2HkIAMKhz08pY1BWUCw5NP9jnkAD
22AAC7yOJSeaDaUwXoM6G5Mp0L6UGQPAme/ArMQmtq1b+T7pyffi0ks4u/XpsPOD
srvkLmU60MhQdxyzJkUTi5bQ9QQGe+L2VlE9tWuj9uASq2cPdc+mxR4fBfGxq8F4
WHUNrTZ71EmE8M2zNNSh6O16J49wSuI+bueeJsQMhT6IQ4PVbQ1thie5JxD74MXi
NkUxqsXGQDrH4vVRRi7WggW1WJp7yw9fw4S77OXG94IbdClbuY088oxZV4IR+6Rj
qNjZfAAKtWSn7ViafoU3jAN7FGE5Xz+/pUQyd//KgS3SWuEKVRTsoaApNakWYxE=
=A1GN
-----END PGP SIGNATURE-----
What about contributing to the automatic development builds -- once
yours works?
Just push your changes to:
https://code.launchpad.net/~grass/grass/grass70_release_debian
Like:
bzr push lp:~grass/grass/grass70_release_debian
You may need to add yourself to the GRASS team at Launchpad:
https://launchpad.net/~grass/+members
If your updated debian files work well, we could re-enable the automatic
builds.
Another possibility is to update lp:~grass/grass/grass70_release_debian
with the following:
https://launchpad.net/~ubuntugis/+archive/ubuntugis-testing/+files
/grass70_7.0-1~svn55286~ubuntu2.debian.tar.gz
BTW, the same need to be done with the 6.4.x series.
I could give you hints if you get stuck. But since I am not on
day-to-day work at GRASS on Ubuntu right know I cannot update the
builders. No time.
Looking forward to your input.
Best regards.
OK, I did it.
Stable (grass6.4.X) Packages are in the grass-stable PPA:
https://code.launchpad.net/~grass/+archive/grass-stable
This includes Ubuntu 12.10 & 13.04!
So let's try to run the recipe daily without errors:
https://code.launchpad.net/~grass/+recipe/grass64
If you want to see how I modified the UbuntuGIS instructions to get the
recipe up, please have a look at:
https://code.launchpad.net/~grass/grass/grass64_release_debian
or the log here:
http://bazaar.launchpad.net/~grass/grass/grass64_release_debian/changes/
For Grass 7.0, recipe was just built for Ubuntu 12.10:
https://code.launchpad.net/~grass/+recipe/grass70
Respective packages are in the grass-devel PPA:
https://code.launchpad.net/~grass/+archive/grass-devel
The debian instructions can be found here:
and the changes in respect to UbuntuGIS at:
http://bazaar.launchpad.net/~grass/grass/grass70_release_debian/changes/
Here a plea -- repeating from my last mail:
* I need help in maintaining this stuff!
* I am not a every day work with GRASS, especially on Ubuntu, these days.
* So I will deactivate the automatic builds again if they fail for 3-5
consecutive times.
* A failure of 1-2 times is usually OK, especially for GRASS7, when the
software is in development. This means that were were some changes in
the GRASS source code.
* If there are build many consecutive failures, the upstream changes are
big and require update of the debian instructions
* this is exactly where help from others is needed!!!
* Further along the road, I could also image that we package GRASS
AddOns for Ubuntu...
Kind regards,
Timmie
Hi Tim,
I can help you with building packages for GRASS. I am already pushing grass70 packages in ubuntugis-testing. So I am ok with packaging.
Please tell me what to do? Is there anything special about grass PPA?
On Sat, Mar 30, 2013 at 6:03 PM, Tim Michelsen <timmichelsen@gmx-topmail.de> wrote:
OK, I did it.
So let’s try to run the recipe daily without errors:
or the log here:
Here a plea – repeating from my last mail:
  • I need help in maintaining this stuff!
  • I am not a every day work with GRASS, especially on Ubuntu, these days.
  • So I will deactivate the automatic builds again if they fail for 3-5
    consecutive times.
  • A failure of 1-2 times is usually OK, especially for GRASS7, when the
  • If there are build many consecutive failures, the upstream changes are
  • this is exactly where help from others is needed!!!
  • Further along the road, I could also image that we package GRASS
    AddOns for Ubuntu…
Kind regards,
Timmie
Rashad
Dear Rashad,
thanks for answering!
Nice.
As you can see here:
the packages are building nicely.
But on my 12.10. starting GRASS returns:
grass70
WELCOME TO GRASS 7.0.svn
   1) Have at your side all available GRASS tutorials
   2) When working on your location, the following materials
      are extremely useful:
      - A topo map of your area
      - Current catalog of available computer maps
   3) Check the GRASS webpages for feedback mailinglists and more:
      http://grass.osgeo.org
      http://www.grass-gis.org
Hit RETURN to continue
Starting GRASS GIS...
python: can't open file '/usr/lib/grass/etc/gui/wxpython/gis_set.py':
[Errno 2] No such file or directory
Received EXIT message from GUI.
GRASS is not started. Bye.
--> this means there's something wrong in the debain/rules
If you could fix that, I think we are well off.
Just branch with bzr:
change and upload again.
If you do not want to wait for LP builds, use pbuilder locally to test
your changes.
Feel free to ask if you have more questions!
Kind regards,
Timmie
<timmichelsen@gmx-topmail.de <mailto:timmichelsen@gmx-topmail.de>> wrote:
    OK, I did it.
    or the log here:
    days.
    consecutive times.
    Kind regards,
    Timmie
   Rashad
