[GRASS-user] Re: problems importing vector and raster data via python script
I'm running a python script under windows/eclipse, where I try to import a shape and a raster file with v.in.ogr and r.in.gdal.
grass.run_command("r.in.gdal",'-o', input='E:\pythoninput\mnyzeron5m.asc', output='dem5m', '-o')
Sonja,
the correct command would be:
grass.run_command("r.in.gdal", input='/path/to/file', output='file', flags='o')
To import ascii files you can use r.in.ascii.
Eng. Margherita Di Leo
Ph.D. Candidate
Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata Campus Macchia Romana
85100 - Potenza Italy
Office: +39-0971205363
Fax: +39-0971205160
