[GRASS-user] Re: QGIS GRASS plugin shadedrelief issue
Date: Thu, 23 Sep 2010 11:06:21 +0300
Subject: Re: [GRASS-user] Re: QGIS GRASS plugin shadedrelief issue
To: nunosousa84 <nuno_sousa_1984@hotmail.com>
Sorry for You.
You do made backup of important data before messing around with QGIS, right?
You can try to launch GRASS and rebuild vector topology with v.build.
If it doesn't help - You'r SOL. And don't forget to infrorm QGIS
developers how "well" their GRASS support works.
Good luck,
Maris.
Hi all.
Sorry I was unclear: it is a known bug for QGIS to crash in case of an unclean
vector. There is no indication that QGIS is more inclined to spoil your vector than
any other GRASS GUI.
If you stop GRASS while it is writing a vector, problems are likely to occur, with
any UI (even from the shell).
You can clean your vector also from within QGIS, by simply running v.build.all.
And yes, backupping data is always a good idea, regardless of what sw you are using.
BTW: Maris, why are you trolling around? We do our best, like everybody, to improve
the tools we are using, for the benefit of everybody, and it's no fun to read your
polemic notes.
All the best.
