I'm using the version that is diretly linked in CompileOnWindows WIKI
because I'm not being able to identify and corretcly select newer versions
for msysCORE-1.0.11-bin, bin-utils, gcc-core, gcc-g++, etc.
Can this be a limitation?
AFAICT I'm using the linked version from the WIKI in my WinGrass-build-environment.
IMHO there should be no limitation.
best regards
Helmut
___________________________________________________________
Neu: WEB.DE De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
Jetzt De-Mail-Adresse reservieren: https://produkte.web.de/go/demail02
Glynn mentioned some possible error associated with gcc version. Any comments about this?
As far as I can see Thy had the same problem last week and antonio is also having this problem. I talked with Antonio and he told me that he never had this problem before. Only now…
Which means that this has something to do with a new improvement/update of osgeo4w or similar
I’m using the version that is diretly linked in CompileOnWindows WIKI
because I’m not being able to identify and corretcly select newer versions
AFAICT I’m using the linked version from the WIKI in my WinGrass-build-environment.
