More info:
gdb gives the following error on running r.in.gdal:
run
gdb: unknown target exception 0xc0000135 at 0x7c964ed1
Program received signal ?, Unknown signal.
Program exited with code 030000000465.
You can't do that without a process to debug.
Internet search indicates that this is a windows error code that it cannot find or load required dll files for the program. I have tried loading LD_LIBRARY_PATH and PATH with all of the correct locations in both cygwin startup and in windows environment variables without success.
Possible related issue: ldd shows r.in.gdal has a dependence on libgrass_gis.6.0.0.dll even though I am running grass 5.4.1. I tried creating a symlink from grass_gis.dll to grass_gis.6.0.0.dll but that did not fix it. It also shows a few other version-specific dependencies.
-------------- Original message ----------------------
I am running grass on Windows XP with Cygwin. I cannot get r.in.gdal to do
anything. It dies with no output.I have installed binaries from grass.itc.it for grass 5.4.1 and grass 6.2.2. and
for gdal. I have built gdal from source without grass or grasslib support, then
built both grass versions from source with gdal enabled. r.out.gdal works but
r.in.gdal dies silently. Also, gdalinfo works and gdal_translate works.Any advice?
