How to install, Where to find it, how is it provided,
r.li.* is not provided in WinGrass. Only on UNIX builds (Mac or
Linux). If you want to use these modules, you may also try the
Cygwin build of GRASS for MS Windows, or try the older r.le
modules.
Dear All,
I've been trying to send this to the list for the past few weeks, seems my mails are being blocked. Anyway, here's another attempt.
I've been trying to use the r.li suite in a landscape ecology course and found the r.li.setup fails to create configuration files if one tries to setup the sampling frame by drawing regions or by using vector layers. The moving window, however, works.
Any suggestions on how to overcome this?
Ravi
Config file for region (2 regions were attempted but the input dialoge did not allow me to digitise the regions of interest.)
SAMPLINGFRAME 0|0|1|1
MASKEDSAMPLEAREA 0.0|0.0|1.0|1.0|one
MASKEDSAMPLEAREA 0.0|0.0|1.0|1.0|two
Config file for vector input (vector comprised of 6 polygons)
On Sunday 03 April 2011 05:22 AM, Hamish wrote:
Nani wrote:
r.li.setup
modules.
On Sat, Jul 30, 2011 at 6:10 AM, Ravinder Singh Bhalla
<rsbhalla@gmail.com> wrote:
Dear All,
Nani wrote:
r.li.setup
modules.
