[GRASS-user] Re: Re: GRASS freezes with OpenSuse 11.0
Hamish,
GRASS 6.3 starts fine with -text or -oldtcltk options. The gui freezes with default or -tcltk or -gui options.
What freezes is the "GRASS 6.3.0 GIS Manager Map" that is a complex map. I can't even close that window and have to logout to get rid of it.
I did the compile myself. This is not from an rpm.
No message about libgdal or missing nsres...
Bill B.
Bill Baker wrote:
I have the same problem with GRASS 6.3.0 downloaded from grass.itc.it under OpenSuse 11.0 32-bit. I have latest GDAL, Postgresl etc.
Francesco Teodori has created 32-bit rpm's for Suse 11 and GRASS 6.3.0, so he must know what we are doing wrong. I have not tried the rpm's:
http://teodori.org/repository/grass/opensuse11.0/current/32bit/grass-6.3.0-1opensuse11.0.i586/download.html
I have the same freeze problem with GRASS 6.2.3 and GRASS 6.3.0-svn from 2 weeks ago, both downloaded from grass.itc.it, so the freeze problem is not specific to either 6.3 release or 64-bit. Something in OpenSuse 11 must be the trouble, but what?
Is there an error message shown in the terminal window?
e.g. something about libgdal.so? or missing nsres() variable?
can you start in text mode ('grass63 -text') and run 'g.region -p'?
I expect there is some build error with those binaries, or GDAL libraries
on your system have been updated to a newer version than those binaries
were built with and are now incompatible.
I see on the download site there is a new grass-6.3.0-13.1.i586.rpm
added three days ago. Perhaps that solves it?
Hamish
Add the following repo http://download.opensuse.org/repositories/home:/lmich/openSUSE_11.0/. After that, update the packages. This should fix the problem.
Francesco
On Thu, Aug 28, 2008 at 1:24 AM, William L. Baker <bakerwl@uwyo.edu> wrote:
Hamish,
What freezes is the “GRASS 6.3.0 GIS Manager Map” that is a complex map. I can’t even close that window and have to logout to get rid of it.
No message about libgdal or missing nsres…
Bill B.
Francesco Teodori has created 32-bit rpm’s for Suse 11 and GRASS 6.3.0, so he must know what we are doing wrong. I have not tried the rpm’s:
can you start in text mode (‘grass63 -text’) and run ‘g.region -p’?
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
Thanks, Francesco and all the other guys in the list.
As I tried some of the suggestions and I needed my system working, I just uninstalled Suse and put a brand new Fedora9 and everything is working fine.
Adalberto
De: grass-user-bounces@lists.osgeo.org [mailto:grass-user-bounces@lists.osgeo.org] Em nome de Francesco Teodori
Enviada em: quinta-feira, 28 de agosto de 2008 04:38
Para: grass
Assunto: Re: [GRASS-user] Re: Re: GRASS freezes with OpenSuse 11.0
Francesco
Hamish,
Bill B.
Hamish
2008/8/28 Adalberto da Silva <adalberto_s@uol.com.br>:
Some times all you need is a bigger hammer...
um abraço.
Paulo Marcondes = PU1/PU2PIX
-22.915 -42.224 = GG86jc
