4. RE: I can?t import postgis layer using v.in.ogr in WinGRASS
(Pablo Carreira)
Hi Pablo. I used your sugestion (without “”) and recieve these messages:
Sorry, <host> is not a valid parameter
Sorry, <user> is not a valid parameter
Sorry, <password> is not a valid parameter
Another sugestion?
Best regards.
Thybério Luna Freire
-------Original Message-------
Date: 10/3/2010 00:43:29
To: grass-user@lists.osgeo.org
Subject: grass-user Digest, Vol 47, Issue 26
Send grass-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
grass-user-request@lists.osgeo.org
You can reach the person managing the list at
grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-user digest…”
Today’s Topics:
- I can?t import postgis layer using v.in.ogr in WinGRASS
(Thyb?rio Luna Freire)
- ps.map: One Script Works, One Doesn’t (Rich Shepard)
- Re: ps.map: One Script Works, One Doesn’t (Rich Shepard)
- RE: I can?t import postgis layer using v.in.ogr in WinGRASS
(Pablo Carreira)
- Re: Running Python scripts inside GRASS (Milton Cezar Ribeiro)
- Re: ps.map: One Script Works, One Doesn’t (Hamish)
- Re: ps.map: One Script Works, One Doesn’t (Dave Kent)
Message: 1
Date: Tue, 9 Mar 2010 16:21:53 -0300
Subject: [GRASS-user] I can?t import postgis layer using v.in.ogr in
WinGRASS
To: grass-user@lists.osgeo.org, grass-stats-request@lists.osgeo.org
Message-ID:
<9e23a6811003091121h43dee098s5c86b29975a2a355@mail.gmail.com>
Content-Type: text/plain; charset=“iso-8859-1”
I´m a Linux/Windows user. Using GRASS in my Ubuntu, i can import postgis
layers by v.in.ogr with facility. But, in my job, the OS used is Windows and
i use WinGRASS.
I just installed PostgreSQL/Postgis to manage my data.
I transfered the db administration to pg:
db.connect driver=pg database=“host=localhost, dbname=gis”
db.login driver=pg database=gis user=postgres pass=*****
until that, all ok…but when:
*v.in.ogr dsn=“PG:host=localhost dbname=gis user=postgres” layer=Municipios
output=Municipios
i recieve the following message:
ERROR: Unable to open data source <"PG:host=localhost dbname=gis
user=postgres…
I searched in all documents and sites and i didn’t find any answer.
I need help.
Thanks!
Thybério Luna Freire - Brazil
An HTML attachment was scrubbed…
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100309/95e77be8/attachment-0001.html
Message: 2
Date: Tue, 9 Mar 2010 11:35:02 -0800 (PST)
Subject: [GRASS-user] ps.map: One Script Works, One Doesn’t
To: grass-users@lists.osgeo.org
Message-ID:
<alpine.LNX.2.00.1003091129320.14989@salmo.appl-ecosys.com>
Content-Type: TEXT/PLAIN; format=flowed; charset=US-ASCII
This has been wasting my time this morning and I’d sure like to learn why.
I have two ps.map input scripts called ‘flowlinedensity.psmap’ and
‘slopes.psmap’. They both compile, but when I view the latter I get a
ghostscript error box, no colortable, and no points legend in the v.legend
area.
Running diff on the two scripts shows only this:
1c1
< raster aber10m.flowdensityAvg
> raster aber10m.slope
48c48
< text 78% 28% Flow Line\n Densities
> text 77% 30% Slope (Degrees)
58c58
< range 0 100
> range 0 25
Since the only differences are the base raster map, text position and
content, and colortable range I fail to see why the latter throws a gv
error.
If I remove the vlegend clause it displays.
Any ideas?
Rich
Message: 3
Date: Tue, 9 Mar 2010 11:45:50 -0800 (PST)
Subject: Re: [GRASS-user] ps.map: One Script Works, One Doesn’t
Message-ID:
<alpine.LNX.2.00.1003091144400.14989@salmo.appl-ecosys.com>
Content-Type: TEXT/PLAIN; charset=US-ASCII; format=flowed
> area.
I should mention that of the 5 maps in the report, the slopes map is the
only one that balks at displaying properly. The only differences are the
base raster and the text contents.
Rich
Message: 4
Date: Tue, 9 Mar 2010 16:48:59 -0300
Subject: RE: [GRASS-user] I can?t import postgis layer using v.in.ogr
in WinGRASS
To: <thyberio@gmail.com>, <grass-user@lists.osgeo.org>
Message-ID: <SNT114-W32657C8DA7DE09E9A44D72D6340@phx.gbl>
Hi Thyberio,
>v.in.ogr dsn=“PG:host=localhost dbname=gis user=postgres” layer=Municipios output=Municipios
>ERROR: Unable to open data source <"PG:host=localhost dbname=gis user=postgres…
Try:
v.in.ogr dsn=PG:dbname=gis host=localhost user=postgres password=******** output=Municipios
Note there is no “” . If it does not work please paste the full error report.
Make sure that pg server is running.
Pablo.
Navegue sem medo: O Internet Explorer 8 te deixa mais protegido. Baixe gratuitamente.
http://go.microsoft.com/?linkid=9707132
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100309/a1ac5b6f/attachment-0001.html
Message: 5
Date: Tue, 9 Mar 2010 13:15:41 -0800 (PST)
Message-ID:
<alpine.LNX.2.00.1003091314350.14989@salmo.appl-ecosys.com>
More testing reveals the problem is with the slope raster map. What in
that particular map might cause an issue with vlegend?
Rich
Message: 6
Date: Tue, 9 Mar 2010 16:22:03 -0500
From: Milton Cezar Ribeiro <miltinho.astronauta@gmail.com>
Subject: Re: [GRASS-user] Running Python scripts inside GRASS
To: Hamish <hamish_b@yahoo.com>
Cc: Sonja Jankowfsky <sonja.jankowfsky@cemagref.fr>, GRASS user list
<grass-user@lists.osgeo.org>, Glynn Clements
<glynn@gclements.plus.com>
Message-ID:
<64f1583f1003091322m702ade4au536045fc8e238d82@mail.gmail.com>
Hi There,
I am happy running python inside a OSGeo4W grass instalallation.
I start MSYS, start grass, and then ryn python 2.5 which are run
from C:\OSGeo4W\apps\Python25. But I needed to copy the grass/python
library to C:\OSGeo4W\apps\Python25\Lib\site-packages.
Good luck,
milton
2010/3/9 Hamish <hamish_b@yahoo.com>
> Sonja wrote:
> > Is there any other place where a wrong PYTHONPATH could be stored???
> if you have the grass source code try from the the msys prompt:
> grep -ri python25 mswindows/*
> wingrass is a bit of a tangle of startup scripts, especially the osgeo4w
> build. the above searches through the custom/lesser known wingrass ones.
> you can also try a recursive grep in the GRASS-64-SVN\ directory to try
> and find and. If doing that I’d add the -I flag to skip searching in
> binaries.
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100309/77109c37/attachment-0001.html
Message: 7
Date: Tue, 9 Mar 2010 13:22:33 -0800 (PST)
Message-ID:
<alpine.LNX.2.00.1003091321420.14989@salmo.appl-ecosys.com>
Fixed it. I re-created the slopes map (r.slope.aspect) and that did the
trick. No idea what was wrong with the original, but something definitely
was.
Rich
Message: 8
Date: Tue, 9 Mar 2010 15:28:06 -0800 (PST)
To: grass-users@lists.osgeo.org, Rich Shepard
<rshepard@appl-ecosys.com>
Message-ID: <67948.82195.qm@web110007.mail.gq1.yahoo.com>
Content-Type: text/plain; charset=iso-8859-1
> latter I get a
> in the v.legend
> area.
> 1c1
> 48c48
> text position and content, and colortable range I fail
> to see why the latter throws a gv error.
> Any ideas?
( and ) need to be quoted like ( and ).
see the documentation for the “comments” instruction, I guess it
applies to “text” as well.
PostScript uses () as the beginning/end delimiter for text
strings.
Hamish
Message: 9
Date: Tue, 9 Mar 2010 16:19:27 -0800 (PST)
Message-ID:
<alpine.LNX.2.00.1003091617500.14989@salmo.appl-ecosys.com>
Hamish,
Actually, they don’t. Originally I had the string in quotes and those
printed, too. The above prints quite well.
As I wrote to the list, I isolated the problem to the base raster map.
Regenerating that fixed the problem.
Rich
Message: 10
Date: Tue, 09 Mar 2010 21:35:28 -0600
To: Rich Shepard <rshepard@appl-ecosys.com>
Cc: grass-users@lists.osgeo.org
Message-ID: <2238A0B6-FF1C-481F-B50E-3F367FB8BA32@sasktel.net>
Content-Type: text/plain; charset=us-ascii
I am having a similar, perhaps related problem.
I have a raster image overlain by a series of vectors.
ps.map fails erratically.
If I remove the raster, it works.
If I remove v.legend, it works. (legend only for vector features)
If I make one specific item in the legend as – lpos 0 – it works.
When all are present in the script, it fails.
When I try to make a pdf with Distiller, the “offending error” is a long numeric string approximately 100 digits long. I opened the postscript file in a text editor and the long string seemed to be associated with the legend. After editing the string, I could open the postscript file.
In other mapsets, things work fine.
The problem appears to be associated with the legend. i have no idea why there is any link with the raster image.
Mac, Snow Leopard, Grass 6.4RC3, Mr. Kyngesburye’s binaries updated today.
Dave
> Hamish,
> Thanks,
> Rich
End of grass-user Digest, Vol 47, Issue 26
