[GRASS-user] 回覆: Re: 回覆: Re: ridge extraction from DEM
Thomas,
Again, you’d have to look to see if this can give you the results you need.
The word “ridge” is a qualitative term that refers to a general landform category. For your purposes, how high does a landform need to be to qualify as a ridge: 1m, 10m, 100m, 1000m? Similarly, how long does it need to be and what is the acceptable range of profile slope along a ridge-top?
These feature extraction methods deal in numbers, so they will probably never exactly match the subjective perception of a landform as a ridge. This is especially true if you are interested in how people (in the past and in the present) perceive a landform and its suitability for settlement. But you should be able to get reasonably close to some kind of consistent perception of what is a ridge, and the GIS methods have the advantage of being explicit, transparent, and repeatable–essential for science of course. But there is probably no “best” method for ID of ridges.
I haven’t tried the convergence method, but will do so to see how it turns out.
Michael
On Jun 12, 2012, at 5:41 AM, Thomaswplee wrote:
What is the difference on convergence and ridge?
Both local convex quadratically double differentiated
I am interesting in application of geomorphology vs social science such as terrain analysis related to human settlement
Thomas
-------- Original message --------
Subject: Re: [GRASS-user] 回覆: Re: ridge extraction from DEM
From: Markus Metz <markus.metz.giswork@googlemail.com>
To: Margherita Di Leo <diregola@gmail.com>
CC: Michael Barton <michael.barton@asu.edu>,grass-user grass-user <grass-user@lists.osgeo.org>,Thomaswplee <thomaswplee@gmail.com>
On Tue, Jun 12, 2012 at 11:28 AM, Margherita Di Leo <diregola@gmail.com> wrote:
there is also r.convergence add-on:
http://grass.osgeo.org/wiki/GRASS_AddOns#r.convergence
BTW, the topographic convergence index is also available in
r.watershed in GRASS 7.
Markus M
madi
On Tue, Jun 12, 2012 at 4:24 AM, Michael Barton <michael.barton@asu.edu>
wrote:
Invert the DEM by multiplying all values by -1 and adding the maximum
original height value. This makes the maximum height 0 and everything less
than that increasingly greater than 0
Run r.watershed on the inverted DEM choosing stream segments as output.
The stream segments from the inverted DEM are your ridgelines. You can
keep them in raster or thin them (r.thin) and convert them to vector
(r.to.vect).
I’ve copied the GRASS user list again because this is a general question
that others might be interested in.
Michael
On Jun 11, 2012, at 7:29 PM, Thomaswplee wrote:
How to make ridge vector line with reversed accumlated flow as in
watershed?
Still reverse DEM plus vectorization of ridge raster?
Thomas
Subject: Re: ridge extraction from DEM
To: thomaslee@starvision.com.hk
CC: grass-user grass-user <grass-user@lists.osgeo.org>
Thomas,
I don’t remember posting anything about r.ppa. I did a quick search and
found a post by Māris Nartišs
(http://lists.osgeo.org/pipermail/grass-user/2005-October/030883.html).
r.param.scale will extract ridges. You will need to adjust the optional
parameters (especially processing window size) to get the ridges you want.
An alternative method is to invert the DEM and run r.watershed on it,
extracting the ‘streams’. The ‘streams’ of the inverted DEM will follow
ridges.
Michael
On Jun 11, 2012, at 9:26 AM, <thomaslee@starvision.com.hk>
wrote:
Dear Michael,
I am interested in ridge extraction but not able to find the r.ppa
mentioned by
Chang, Y.C., Frigeri, A., 2002. Implementing the automatic
extraction of ridge and valley axes using the PPA algorithm in
Grass GIS. In: Open Source Free Software GIS GRASS
Users Conference, 2002.
Implementing the automatic extraction of ridge and
valley axes using the PPA algorithm in Grass GIS
Do you have any solution since your message in 2007 about ridge
extraction.
C. Michael Barton
Visiting Scientist, Integrated Science Program
National Center for Atmospheric Research &
University Corporation for Atmospheric Research
303-497-2889 (voice)
Arizona State University
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
C. Michael Barton
University Consortium for Atmospheric Research
grass-user mailing list
Dr. Margherita Di Leo
C. Michael Barton
Given your objectives, I think r.param.scale or r.prominence would be your best choices.
Michael
On Jun 14, 2012, at 2:29 AM, Thomas Lee wrote:
Hi Michael
My approach of voting is trying to solve the subjective human perceptaion of landforms per culture.
Voting here means sample population test at defined culture such as
Culture 1, Sample size n = 300, Mean = 5, S.D. = 2, Sampling Time = T1
Culture 2, Sample size n = 500, Mean = 4, S.D. = 3, Sampling Time = T2
Culture 3, Sample size n = 1000, Mean = 6, S.D. = 1, Sampling Time = T3
They are dynamic and can be stored in a database.
They are temporal information (voting information), subject to change per year (or per month depended on the attribute sensitivity to the time), per culture (spatial location).
It is better put in a web database server and update globally and remotely by mobile device such as android phone and iphone.
All come together as a knowledge base (I am used to do it in my M.Sc. thesis, about 20 years ago, on spatial decision support system for location-allocation analysis using concept of expert system, knowledge base, model base, data base… etc)
Thanks for introducing “Prominence”.
It is same as the Feng Shui “Mountain Ridge” system logic (or Form School).
The masters have been studying these for, it is beleived that, thousands of years.
Their concept is to locate the best site by studying the lineage of prominence.
For country capital, they focus in top range or high level hierarchies lineage of prominence
For smaller captial such as provincial capital, they use middle range lineage
For small city or village, they use lower range lineage.
The spot they want to locate is likely a flat area at the end of a gentle slope ridge line with big openning in front and surrounded by embracing ridges.
With this pattern, stream lines will be converged in front of the site and having high quality of soil content suitable for substaintable living.
I consider this logic can be proved by analyzing
  • the prominence network
  • length of lineage
  • height of parent and subpeak
  • total lengeth of river/stream network
  • accumulated flow of water (accumulate rich content in water)
  • accumulated length of ridge line (in Feng Shui, they interested in the Energy (Qi) bring along through the mountain ridge line, longer the line, high energy, better benefit to the site)
  • formation of a complete mountain hierachies of line parent and subpeak (stored in a mountain hierachy database)
  • entropy of peak (distribution of peak)
  • ridge pattern recognition (Feng Shui has its mountain dragon (ridge) pattern system such as Lotus Pattern)
The MH database
  • Table of Mountain, point layer
  • Table of lineage, line layer (route structure like road network with junction as peak or subpeak)
  • Table of stream node, point layer
  • Table of stream/river, line layer (route structure)
  • Table of event (like road side event such as accident, but here is Feng Shui site, village, capital, city)
Thomas
----- Original Message -----
To: Thomas Lee
Sent: Thursday, 14 June, 2012 1:43 AM
Subject: Re: 回覆: Re: [GRASS-user] 回覆: Re: ridge extraction from DEM
Hi Thomas,
You can indeed come up with quantitative definitions. My point is that these will have a variable match to subjective human perception of landforms. The ranking you list below can be applied to any topographic prominence, including landforms called hills, bluffs, ridges, etc. The question of ridges (as long, relatively narrow landforms) is slightly different from one of topographic prominence. There is in fact a module (I think it is called r.prominence) in addons that will ID topographic prominence by various characteristics that you can set. Maybe it would be of use to you.
Michael
On Jun 13, 2012, at 10:20 AM, Thomas Lee wrote:
Michael
The qualitative definition of ridge can be quantitatively modeled as
size in metre; degree of size of ridge
1; 1
5; 2
10; 3
50; 4
100; 5
1000; 10
Normally a flat area bigger than 1000m is a platform where a small village can be accomodated.
The above can be modelled by fuzzy membership function which can be implemented in GRASS
By having questionaire in different cultures at different locations globally, the result could be like voting in expert system voting model for spatial decision support system.
I am interested in the correlation of the spatial cluster of human settlement to the pattern of ridges. Not a ridge but spatial pattern of a group of ridges.
It is going to test the Chinese Feng Shui concept. Feng Shui is the ancient technique in site selection. To find a site good for living over say hundreds or thousands of years for next generations based on geomorphically terrain pattern or Mountain Form. There are systems in Feng Shui where the Master study the ridge pattern (and stream pattern) to find the site with good soil content without using modern borehole or lab test technique.
Thomas Lee
To: Thomaswplee
Cc: markus.metz.giswork@googlemail.com ; diregola@gmail.com ; grass-user@lists.osgeo.org
Sent: Wednesday, 13 June, 2012 1:39 AM
Thomas,
Michael
Thomas
Markus M
madi
(r.to.vect).
Michael
watershed?
Thomas
Thomas,
ridges.
Michael
wrote:
Dear Michael,
mentioned by
extraction.
C. Michael Barton
C. Michael Barton
C. Michael Barton
C. Michael Barton
C. Michael Barton
