Dear Hamish and all
I succeeded in the compilation from the source of grass.
lubuntu 11.04
grass6.4.1
Because the error was output with configure, final script is as follows.
./configure --with-tcltk-includes=/usr/include/tcl8.4/ --with-proj-share=/usr/
share/proj --with-sqlite --with-geos
g.extension operated, and d.barb was also installed.
The compilation was the first experience for me. The homepage of grass was pro
fitable.
I wish to express my gratitude to Mr. Hamish.
Thank you.
Best
Yasuo shimada ( Japan weather association )
----- Original Message -----
Date: Wed, 29 Jun 2011 14:33:12 +0900 (JST)
To: grass-user@lists.osgeo.org
Subject: Re: Why does g.extension fail...?Dear all
if you are anxious for a solution right now, the surest way
is to build GRASS from source code, and copy the addon module
into the source tree after building, and `make` by hand.Oh...I will try and challenge though it seems to be difficult for me the wor
k
I will install 'd.barb' as following.
Is this follow a correct ?My object is to install addon 'd.barb' into grass6.4.1 binary (already exists
(1) Obtain source of grass source
svn co svn://svn.debian.org/svn/pkg-grass/packages/grass/trunk/(2) Obtain source of d.barb
svn co https://svn.osgeo.org/grass/grass-addons/display(3) extract (2), and copy 'd.barb folder' to /usr/local/src/trunk/display/
(4) cd and sudo su
cd /usr/loacal/src/trunk(4)configure and make install 'd.barb' only..
./cofigure --target=d.barb
make libs
make MODULE_TOPDIR=/usr/lib/grass64/It feels sorry also because I am a beginner of linux....
Best
Yasuo shimada ( Japan Weathe Association )----- Original Message -----
Date: Tue, 28 Jun 2011 10:57:26 +0900 (JST)
Subject: Why does g.extension fail...?Dear grass users
I succeeded in installing d.barb the other day.
Because d.barb was very wonderful addon, I tried installing to other PC.
However, I fail in the installation....I tried on the following conditions.
(Case 1) ubuntu11.04 wubi version on Windows7
---> Success(Case 2) ubuntu10.04 vmware version on Windows X
---> failed(Case 3) lubuntu11.04 vmware version on Windows 7
---> failedIn Case 2 and 3, the same error message is output as follows.
The log might not be read easily for you in a Japanese mode...--- begin message ---
GRASS 6.4.1 (newLocation_5):/home/shimada > g.extension extension=d.barb
Fetching <d.barb> from GRASS-Addons SVN (be patient)...
A d.barb/legend.c
A d.barb/local_proto.h
A d.barb/main.c
A d.barb/description.html
A d.barb/grid.c
A d.barb/Makefile
A d.barb/points.c
A d.barb/draw.c
U d.barb
リビジョン (revision )46793 をチェックアウト(checkout)しました。
Compiling <d.barb>...
/usr/lib/grass64/include/Make/Grass.make:418: 警告(warning): ターゲット(targ
e
t
) `/usr/lib/grass64/bin' へのコマンド(command)を置き換えます(replace)
/usr/lib/grass64/include/Make/Grass.make:409: 警告(warning): ターゲット(targ
e
t
) `/usr/lib/grass64/bin' への古いコマンド(old command)は無視されます(ignore)
make: `/usr/lib/grass64/dist.i486-pc-linux-gnu' に対して行うべき事はありません
Installing <d.barb>...
You need to enter the root password next to install d.barb:
/usr/lib/grass64/include/Make/Grass.make:418: 警告(waring): ターゲット(targe
/usr/lib/grass64/include/Make/Grass.make:409: 警告(warning): ターゲット(tage
t
/usr/bin/install -c /usr/lib/grass64/bin/d.barb /usr/lib/grass64/bin/
/usr/bin/install: `/usr/lib/grass64/bin/d.barb' を stat できません(can not):
N
o such file or directory
make: *** [install] エラー 1 (error 1)
エラー(error): Installation failed, sorry. Please check above error message
s
---- end of message ---
I don't understand that though there is '/usr/lib/grass64/bin/', error messe
g
e
'can not stat' output..
I tried all cases by user and root(su).
I changed to permission of '/usr/lib/grass64/' from read only to read and wr
i
t
e . Of course,
I also corrected two make files in all casees;
/usr/lib/grass64/make
Platform.make
Grass.make
http://www.mail-archive.com/grass-user@lists.osgeo.org/msg16723.html
---I want you to give profitable information by all means...
Or, please teach other installation method.Best
Yasuo SHIMADA
