[GRASS-user] Re: restoring region
Seb wrote:
Checking:
,-----[ ldd /usr/lib/grass64/bin/g.region | grep 'not
found' ]
| libgrass_vect.so => not found
| libgrass_dbmibase.so => not found
| libgrass_gis.so => not found
In fact, doing this for /usr/lib/grass64/bin/* gives a
pretty long list (1954). Could this be the problem?
it sure won't help! ... get that fixed first.
Hamish
On Mon, 15 Jun 2009 04:01:11 -0700 (PDT),
Hamish <hamish_b@yahoo.com> wrote:
Seb wrote:
Checking: ,-----[ ldd /usr/lib/grass64/bin/g.region | grep 'not
found' ] | libgrass_vect.so => not found |
libgrass_dbmibase.so => not found | libgrass_gis.so => not found
In fact, doing this for /usr/lib/grass64/bin/* gives a pretty long
Ok, that turned out to be a feature if you saw my bogus Debian bug
report Bug#533191.
So I went back to bare essentials:
$ mkdir grassdata
$ ls -l
drwxr-xr-x 2 sluque sluque 4.0K 2009-06-16 21:02 grassdata
$ grass -text
# Chose to set up a "Other Projection" location in the newly created
# database, and right after typing the "one line description" for the
# location:
Please enter a one line description for location <Hudson_Bay_AEA>
test
test
ok? (y/n) [y]
ERROR: region for current mapset is not set
       run "g.region"
So now I don't think this has anything to do with the restored data, and
am very stuck wondering what is wrong, even though nothing seems wrong
outside of GRASS. Any further advice on what to look for appreciated,
particularly how to debug this problem (setting DEBUG=3 before calling
grass in the code above gave the same level of messages). Thanks.
Seb
On Tue, 16 Jun 2009 21:17:47 -0500,
and am very stuck wondering what is wrong, even though nothing seems
wrong outside of GRASS. Any further advice on what to look for
appreciated, particularly how to debug this problem (setting DEBUG=3
before calling grass in the code above gave the same level of
messages).
The only way I can create a new location in the newly created DATABASE
as in my code in my previous post is to choose option "B"
(Latitude-Longitude projection). Any other choice gives the error, so
perhaps some problem with locating projection data files in the system?
Seb
