[GRASS-user] Re: Space Oblique Mercator (SOM) and "lsat" project code
I'm new to GRASS - bear with me:-)
Currently I'm working on a watershed risk assessment task where I have Landsat TM data spanning over a 20 year period. In order to convert all the different Landsat projections to one common georeferenced ground I want to import the raster files into separate mapsets with original projections as a first step.
One set of data is from USGS (Landsat 5 TM .tif files) based on Space Oblique Mercator (SOM) projection.
Here is my problem: How do I correctly transform the metadata information from the USGS Landsat 5 .hdr file using the 'lsat' projection code in GRASS (using GRASS 6.1 cvs, WINDOWS version)?
The .hdr file received from USGS reads as follows:
  "PRODUCT =00240248-01 WRS =130/04500 ACQUISITION DATE =19921111 SATELLITE =L5 INSTRUMENT =TM10 PRODUCT TYPE =ORBIT ORIENTED PRODUCT SIZE =FULL SCENE TYPE OF GEODETIC PROCESSING =SYSTEMATIC RESAMPLING =CC RAD GAINS/BIASES = 00.00398/-0.0100 00.00964/-0.0232 00.00540/-0.0078 00.01043/-0.0193 00.00235/-0.0080 00.00000/0.00000 00.00154/-0.0040 TAPE SPANNING FLAG=1/1 START LINE #= 1 LINES PER VOL=40096 ORIENTATION = 86.36 PROJECTION =SOM USGS PROJECTION # = 21 USGS MAP ZONE = 100 USGS PROJECTION PARAMETERS = 0.637813700000000D+07 0.669437999000000D-02 0.988800000000000D+02 0.144000000000000D+04 0.980130120103547D+08 0.129299998692014D+03 0.233000000000000D+03 0.339078914728310D-19 0.339078914728310D-19 0.339078914728310D-19 0.339078914728310D-19 0.339078914728310D-19 0.339078914728310D-19 0.339078914728310D-19 0.130000000000000D+03 EARTH ELLIPSOID =WGS84 SEMI-MAJOR AXIS =6378137.000 SEMI-MINOR AXIS =6356752.314 PIXEL SIZE =30.00 PIXELS PER LINE= 6920 LINES PER IMAGE= 5728 UL 1000636.4421E 223245.7618N 17609006.551 241587.518 UR 1015119.6129E 221736.3799N 17620546.108 423081.037 LR 1012926.4911E 204635.4062N 17791358.336 401458.922 LL 0994549.6437E 210131.2130N 17779824.490 220055.220 BANDS PRESENT =1234567 BLOCKING FACTOR = 1 RECORD LENGTH = 6920 SUN
  ELEVATION =42 SUN AZIMUTH =142 CENTER 1004816.6229E 213945.8926N 17700964.419 321293.145 3349 2865 OFFSET= 28 REVB"
How do I correctly convert this info to the "lsat" project code command structure in GRASS? Some parameters are obviously known from the header file info, e.g. Satellite Number (= 5), Satellite Path Number (= 130), ellipsoid name (= wgs84). How about the remaining info?
Secondly, is there a way to make on the fly project conversions, from SOM to UTM 47, using the OGR tool?
Thanks for any hints on how to proceed.
Anders Fahlén
Agronova
Sweden
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.1.394 / Virus Database: 268.9.0/368 - Release Date: 2006-06-16
On Sunday 18 June 2006 01:59, Anders Fahlén wrote:
PRODUCT SIZE =FULL
SCENE
1015119.6129E
1012926.4911E
0994549.6437E
1004816.6229E
See what gdalinfo thinks about these files. If it can read their coordinate
system, chances are that you will be able to warp them to any new coordinate
system with little difficulty.
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
coordinate system, chances are that you will be able to warp them to
any new coordinate system with little difficulty.
moreover, if gdalinfo is happy, try the "r.in.gdal location=" option to
create a new (projected) location for the image automatically.
In GRASS 6.1 you can do this from the startup screen.
Anders:
yes, for things like coordinates (also m.proj in GRASS 6.1).
for LANDSAT images use gdal_transform and/or gdalwarp.
Hamish
Hamish and Dylan,
Thank you very much for your suggestions. I will check what gdalinfo reports and try to create a new projected location.
Anders Fahlén
Agronova
Sweden
<snip>
