[GRASS-user] Re: stream network extraction
Thank you for your work, Markus, it’s wonderful :slight_smile:
Best,
Margherita
in grass-addons is a new module for clean stream network extraction from
flow accumulation. It can extract streams from accumulation maps
generated with any method (D8, FD8, D-Inf, DEMON, etc) and any software,
granted that exactly the same elevation map is provided that was used to
calculate flow accumulation. In case of r.terraflow, that would be the
flooded (filled) output elevation map, not the elevation map used as
input for r.terraflow. For e.g. TAS flow accumulation as input, it must
be the elevation map used within TAS to calculate flow accumulation.
r.stream.extract output is available as raster and vector with unique
stream IDs. The vector is a complete network with stream segments and
points for stream heads, confluences and outlets. The raster output can
be used as input for the r.stream.* modules of Jarek, also in grass-addons.
Markus M
