[GRASS-user] Re: stream network from DEM
Thanks Dylan
In ArcInfo, If DEM data is g, do the following:
/*get flow direction, gfdir is the flowdirection grid
gfdir = flowdirection(g)
/*get curvature, gcurv is the curvature grid
gcurv = curvature(g)
/*threshold curvature, gcthresh is thresholded grid of curvature, cells with curvature > 0.03 will be set 1, otherwise will be set to nodata. here using 0.03 as an example
gcthresh = con(gcurv > 0.03, 1)
/*the above grid is a 1 or nodata grid that should represent the streams but may be broken segment, to connect them, do the following
gfacc = flowaccumulation(gfdir,gcthresh)
/*set stream grid to 1 on nodata background
gstrm = con(gfacc > 10, 1)
Is there any other command to calculate flowaccumulation in GRASS which function is the same as FLOWACCUMULATION in ArcInfo?
FLOWACCUMULATION(<dir_grid>, {weight_grid})
Date: Mon, 26 Feb 2007 19:59:05 -0800
Subject: [GRASS-user] Re: stream network from DEM
To: Xiaoyan Li <xlia@gmu.edu>, grassuser@grass.itc.it
Message-ID: <200702261959.05473.dylan.beaudette@gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
On Sunday 25 February 2007 07:38, Xiaoyan Li wrote:
> hi,Dylan,
> I searched the following discusses about flow accumulation
calculations on
> Internet. http://grass.itc.it/pipermail/grassuser/2006-
May/034150.html> http://grass.itc.it/pipermail/grassuser/2006-
February/032744.html
Hi!
Apologies for the late reply. Those messages should have some good
hints on calculating flow accumulation.
> Do you think it is possible to do the same thing in GRASS as
extracting> stream network via detection of curvatures from DEM?
It might be, but I am not the one to tell you how to do it. You
might have to contact some of the developers like Helena for the specifics.
> I tried to do the same using following commands:
> Filling DEM: r.fill.dir
> Calculating tangential curvature: r.slope.aspect
> Thresholding tangential curvature surface: r.mapcalc (?guess)
> Thinning the result grid to get network segments: r.thin
> Run flowaccumulation function with network segments as weight to
> connect stream segments: r.watershed or r.flow or r.terraflow
> Weight to connect stream segments? r.mapcalc (?guess)
Seems like you are on the right track, but again I am not a
hydrologist and do not have a lot of time to investigate further.
> I don't know about hydrology. Someone ask me help to implement
this in
> GRASS. I am in a bit of quandary here:
> How to threshold tangential curvature surface?
> How to weight to connect stream segments?
Try asking again, but with a more concise description of a part of
the problem. Simple questions -- easier for more to answer.
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
grassuser mailing list
End of grassuser Digest, Vol 10, Issue 54
On 2/27/07 9:02 AM, "Xiaoyan Li" <xlia@gmu.edu> wrote:
Thanks Dylan
=aspect (r.slope.aspect or r.param.scale or calculated from r.mapcalc)
=profile curvature (r.slope.aspect, or r.param.scale)
0.03 as an example
do in r.mapcalc, using curvature map from r.slope.aspect/r.param.scale
Multiple ways of getting flow accumulation (r.terraflow, r.flow,
r.watershed). Choose your algorithm and optimization parameters depending on
your problem.
I'm not sure what the con() function is in this statement. Probably you need
an r.mapcalc statement here.
As I indicated above, there are multiple algorithms for calculating flow
accumulation. They are well-documented (as opposed to at least some of the
algorithms in Arc*).
r.watershed also will automatically generate a stream network for you as one
of its output options.
Hope this is helpful
Michael
hi,Dylan,
calculations on
Hi!
this in
Dylan Beaudette
530.754.7341
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
