-------- Original-Nachricht --------
Datum: Thu, 19 May 2011 07:11:47 +0100
Von: Glynn Clements <glynn@gclements.plus.com>
An: "Johannes Radinger" <JRadinger@gmx.at>
CC: grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] Re: Using temp files in Grass Script
Johannes Radinger wrote:
> > Using an exit handler ensures that the temporary map gets removed
> > regardless of how the script terminates (e.g. if it terminates due to
> > an exception).
> Thank you for your nice examples how to do that with tmp files and the
exit handler.
> Just some questions:
> 1) is the PID also used on windows systems? so can it be integrated
> in a script which also windows users want to use?
Yes.
> Is it correct that the PID is the same value for running the whole
> script one time?
Yes.
> 2) what exactly does the "global tmpmap"?
First, it should have been "global tmp_map", not "global tmpmap".
"global" declares a variable as global, so that any assignment to that
variable within the function modifies the global variable rather than
creating a local variable with that name.
In order to assign a global variable from within a function, it must
be explicitly declared "global". A "global" statement isn't required
to read a global variable.
In this case, tmp_map must be global so that the name generated within
main() can be used from within cleanup().
> 3)I've got a lot of tmp-files which will be created during the
> process, so is there and option to tell the g.remove that all maps
> containing .tmp.%d' % os.getpid() in the end should be removed
> instead of typing all the tmp map files into the list of g.remove.
You could use g.mremove to remove multiple maps based upon a pattern,
but I would recommend specifying all of the temporary maps explicitly.
If an option for a GRASS command accepts multiple values (e.g. all of
g.remove's options), you can pass a Python list via
grass.run_command(), e.g..
grass.run_command('g.remove', rast = [tmp1, tmp2, tmp3])
> 4) so the whole thing works that in the end all the tmp maps are
> deleted after the processing of the script and after an exception
> etc.
An exit handler registered using atexit.register() will be run when
the script terminates, whether due to reaching the end of the script,
calling sys.exit(), an uncaught exception, Ctrl-C/Ctrl-Z, etc.
The only situation where it won't be run is if the Python interpreter
crashes (or is terminated with SIGKILL on Unix, etc), which can't
realistically be handled by any means.
grass-user mailing list
Okay I think I managed to do everything according to your really good explanation (Thank you!). Here how I implemented the tmp maps including the PID and deleting it via the cleanup and a list containing all tmp maps:
tmp_map_rast = None
tmp_map_vect = None
def cleanup():
if (tmp_map_rast or tmp_map_vect) and not flags['a']:
grass.run_command("g.remove",
rast = tmp_map_rast,
vect = tmp_map_vect,
quiet = True)
def main():
#global variables for cleanup
global tmp_map_rast
tmp_map_rast = [f + str(os.getpid()) for f in['rast1_tmp_', 'rast2_tmp_', 'rast3_tmp_']]
global tmp_map_vect
tmp_map_vect = [f + str(os.getpid()) for f in['vect1_tmp_', 'vect2_tmp_', 'vect3_tmp_']]
if __name__ == "__main__":
options, flags = grass.parser()
atexit.register(cleanup)
sys.exit(main())
I tried it once and it worked! I hope it a good way how i did it, but probably there is always something to make better. Anyway thanks a lot!
/Johannes
NEU: FreePhone - kostenlos mobil telefonieren!
Jetzt informieren: http://www.gmx.net/de/go/freephone
