[GRASS-user] RE: Where the grassdata base resides
Hiya,
I have no probs with my GRASS having been set up (on Ubuntu)
at /home/my-home/GIS/GRASSdata, which, for you, might be equivalent to
c:/users/path-to-your-folders/GIS... (sorry, haven't used that OS for
awhile)...
I'd also recently installed it on a colleagues laptop, I think they were
running Vista or 7... I think I put the GRASSdata somewhere on their
user's desktop... I was in a rush, and struggling to remember my way
around windows so unfortunately can't recall much of the detail to help
you. But the program did work fine.
I was already aware that whitespace in folder/directory names is a bad
practice (at least in my experiences.. even though i think windows still
works ok with them, your GRASS installation, having been born from
another family, still might not like them) so in my previous example I
know I actively avoided that. if_you_insist_on_spaces,...be\ prepared\
to\ possibly\ do\things\ differently... :slight_smile:
Did you install GRASS, then try moving the folder location? that may
have confused some of the startup settings and cause your crash?? not
sure if/how to edit startup stuff if this is your case, might be best to
try clean install to your desired location.. unless you've already tried
this.
Maybe, if you don't get it solved 'neatly', a sym-link from C: to where
you prefer to keep GRASS??
my two cents :wink:
-shane
hi greg,
yes, QGIS is good - I started with that but, in my stubbornness, decided
to see if I could master GRASS without any 'shortcuts' hehe.. when I
initially set up my GRASS install too, I was actually doing it through a
terminal/command-line... I don't think the GUI / point-and-click option
was fully functional then (a coupla years ago)...The upside of that
method meant it was one-step-at-a-time, and the terminal berated me if I
got something awry like directory, resolution, projection, etc...
if you find something like QGIS that makes your GRASS entry easier, go
for it. About the only 'down' thing I found with QGIS was it took some
time to refresh when I was using some of my high-res pics, whereas this
seemed less of an issue directly in GRASS. But it's probably improved a
lot in last year or so... I'm due to play with it again soon :slight_smile:
shane.
On Thu, 2010-12-09 at 23:48 -0800, Greg Corning wrote:
Shane,
    Thanks. That was much more than two cents' worth. I am playing
around with things now, and the main thing, I think, is eliminating
the spaces in file paths. Also, I have found by accident in the
process of following a tutorial on QGIS that QGIS is a great interface
for working with GRASS.
     Thank you for answering my question.
Catlike
On Thu, Dec 9, 2010 at 2:22 AM, Shane Litherland
<litherland-farm@bigpond.com> wrote:
> Hiya,
> awhile)...
> this.
> my two cents :wink:
> -shane
